Old 05-06-2008, 05:08 PM   #1 (permalink)
Titan Speaker Mount
In the 2006 CC, do you have to replace the speaker mounts in the back in order to fit 6.5s? Can you mount the speaker to the factory mounts like the 6x9s up front?
I decided not to do any subs under the seat. Instead I'm going to do the Kicker 6.5" CVTs in the back doors with either some Kicker 2-way 6x9s up front. Will use a Kicker 550.3 to run it all. Going with the Pioneer 4000 series dvd indash.
The 6.5s are actual subs and not midbass so I'm curious how it will sound.
Kicker 550.3
70x2 wrms @ 4-ohms for the 6x9s
420 wrms @ wired at 2-ohms for the CVTs.
Kicker CVTs
Single 4-ohm
150 Wrms each
Kicker KS692s
Single 4-ohm
90 wrms
fam4life is offline   Reply With Quote
Old 05-06-2008, 05:19 PM   #2 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
Re: Titan Speaker Mount
GOOD LUCK WITH THIS!!!!! MAke sure you seal the door up and yes you have tomake a mount for the 6.5s
Please check out www.tech12volts.com
tech12volt is offline   Reply With Quote
Old 05-06-2008, 05:57 PM   #3 (permalink)
slwilson6's Avatar
the rear speakers and mounts are all one unit. the easiest way to do it is take some 5/8" mdf and trace around the rear speaker assembly. Then do it again but dont trace where the bolts tabs go. glue those two peices together, determine how big of a hole for the new speakers and cut that out in the center. this makes an even 1 and a 1/4" (same depth as the factory speaker assembly). I have considered using mid drivers in my doors as well. let me know how that sounds. It may not give the really low ranges that a sub would, but with as much power you will be pushing....holy ____....bet that will be loud as hell!!!! let me know how it goes.
07 TITAN CREW CAB LE 4X4, 18X9 CUSTOM RIMS, BFG RUGGED TRAILS, TOW PACKAGE, WESTIN DRIVING LIGHTS, TOO MUCH AUDIO EQUIP TO LIST.
slwilson6 is offline   Reply With Quote
Old 05-06-2008, 06:01 PM   #4 (permalink)
Send a message via AIM to r4mz1
Yes, pics please
r4mz1 is offline   Reply With Quote
Old 05-07-2008, 10:57 AM   #5 (permalink)
post some pics when your done plz
07' 4x4 Nissan Titan
15% tint
24' American Racing wheels
294/45/24 Falken Tire
Gdub88 is offline   Reply With Quote
Old 05-14-2008, 07:33 AM   #6 (permalink)
Change in plans...going active:
H/U: Pioneer 880prs (Arrives tomorrow)
Mid/High Amp: Tsunami DB4440 (Arrives tomorrow)
Highs: Seas 1" Silk Tweets (Arrived)
Mids: Peerless 6.5" (Arrived)
Rear: 6.5"s CVTs, Mach 5, Peerless (undecided)
Rear Amp: Undecided. Nothing more than 300wrms.
Trying not to use subs but I may go with two 8s.
Now. I have zero experience with wood work so who can make me some speaker rings at a decent price? I can pay now!
Old 05-14-2008, 07:42 AM   #7 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
I hope you have experience in going active! Its a lot harder than making speaker rings! haha
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
t22a80 is offline   Reply With Quote
Old 05-14-2008, 08:16 AM   #8 (permalink)
tech12volt's Avatar
I can make rings . I cut them out of 1 inch MDF and they are 35 a set front and rear.
Old 05-14-2008, 08:48 AM   #9 (permalink)
Not worried about that. If I had the space and equipment needed to do some wood working, I would but I don't so I pay.
Tech:
I'll send a request through your online store this afternoon.
Old 05-14-2008, 02:20 PM   #10 (permalink)
tech12volt's Avatar
[quote=fam4life]Not worried about that. If I had the space and equipment needed to do some wood working, I would but I don't so I pay.
Tech:
I'll send a request through your online store this afternoon.[/QUOTE
No problem
Old 05-21-2008, 06:14 PM   #11 (permalink)
Well got the H/U installed. It sounds great with just the factory speakers. The speaker and amp install will happen this weekend. Waiting for the 6.5 CVTs and the Kicker 300.1 to come in. I'll take pics of the door installs considering I'm using subs instead of mid-range speakers in the back.
Tech12Volts: I sent a request on your site but not sure if you got it.
Old 05-21-2008, 07:39 PM   #12 (permalink)
tech12volt's Avatar
Nope did not get it. Send it again.
Titan Speaker box for sale Mighty Moe Buy/Sell 9 05-07-2008 10:59 AM
WTB- 06 Titan rear speaker AMP 3dad Buy/Sell 14 08-23-2007 04:05 AM
Titan radio mounts metra scoshe--1 ISO singele mount, and 1 scoshe double din mount smoketitan Buy/Sell 9 04-03-2006 10:21 AM
Titan Speaker Impedance (Non-RF) ba01raptoraz Titan Visual & Audio Discussion 4 11-09-2005 02:52 PM
