Old 05-16-2008, 11:25 AM   #1 (permalink)
SeahawksTitan's Avatar
Sirius install pics
Hey guys, thought I'd share my latest addition to my truck with ya. Just got Sirius and loving it...I put 1.5-2k miles on the road every month for work, and right now I'm not sure how I went so long w/o it!
Anyways, I spent a couple hours yesterday doing the sirius antenna-on-break light mod, and decided I didn't want GPS AND Sirius wires laying all over the place, so I routed everything behind the dash. I drilled a small hole in the middle of the center coin tray above the radio, cut a small slice through the rubber mat, and secured it all down with trusty double sided tape. I wasn't sure if I wanted to attempt to hardwire anything, so I ran the cig adapters along the inside lefthand side of the glovebox, and found that there is enough room there that it will still shut when they are plugged in, or I can tuck them in the glovebox when not in use. I think it turned out pretty nice...
sirius-install-pics-dsc00558.jpg  sirius-install-pics-dsc00561.jpg  sirius-install-pics-dsc00562.jpg
__________________________
2006 Smoke XE 2WD KC
Lucky Seahawks Mirror Ball
Sirius Satellite Radio
Garmin Nuvi 200
17" ATX Predator Teflon wheels
Ultraliner spray-on bedliner
Bakflip G2 bed cover
SeahawksTitan is offline   Reply With Quote
Old 08-25-2008, 10:46 AM   #2 (permalink)
Re: Sirius install pics
Thanks for the idea, This is what I was thinking something similar but didn't know how easy it would be to get the wires to the top of the dash.
budiii3 is offline   Reply With Quote
Old 08-25-2008, 04:17 PM   #3 (permalink)
I did pretty much the same thing with my XM Unit. But! if you remove the radio panel you can unscrew the aux input jack from the panel. Then plug your siruis into it behind the panel and then it will be completely hidden. I then covered the aux jack hole in the dash with black piece of plastic. then i got a 12 outlet extension cord at radio shack. cut the jack end off and spliced it in behind the radio panel as well. then plug the sirius power cord into it inside the dash as well and boom! no wires outside at all. I can take a pic later if you want.
SethMan408 is offline   Reply With Quote
Old 08-26-2008, 03:56 AM   #4 (permalink)
If you get a chance I would be very interested in seeing this. There aren't too many other convenient locations to mount one of these without blocking something.
Old 08-26-2008, 08:34 AM   #5 (permalink)
Heres my install.
sirius-install-pics-p1000979.jpg  sirius-install-pics-p1000980.jpg  sirius-install-pics-p1000981.jpg  sirius-install-pics-p1000983.jpg
Old 08-27-2008, 12:14 PM   #6 (permalink)
mike_d's Avatar
I put my gps on the little circle area underneath the middle left vent where I think the 4WD switches are for those with that option. The metal disc with adhesive fit perfectly there and it is in the perfect position for viewing gps while driving, I didnt hide the wires though. The battery lasts 8 hours and I dont use it that long normally.
mike_d is offline   Reply With Quote
Old 08-27-2008, 01:09 PM   #7 (permalink)
juscuzram's Avatar
Send a message via AIM to juscuzram
I've been trying to find an iPod mount that will fit in that little circle but I can't find one
Jus Cuz Designs...Respect This!
MYSPACE
2006 Nissan Titan SE KC
Big Tow
NCD 2.5" Leveling kit
Toyo Open Country A/T
Magnaflow Duals
Hurst T-Handle
T-Rex Billet Grille Inserts
Panasonic CQ-C8300U Head
Memphis MClass 10s
Memphis SC 1.500 Amp
Memphis MClass 6x9s
Memphis Tweets
Autotek SS490.4 Amp
juscuzram is offline   Reply With Quote
Old 08-28-2008, 11:28 AM   #8 (permalink)
drg titan's Avatar
sirius-install-pics-sat.jpgHey, i had my sat. receiver there and i moved it to the overhead console.What do you think?
Sorry for the hijack.
SILVER '04 CREWCAB,BIG TOW ,OFFROAD,
TORZA TRIFOLD TONNEAU,ALTEZZA EURO TAILS,L.E.D.3RD BRAKE LIGHT.AIRRAID INTAKE,TAILGATE HANDLE CHROME,BILLET GRILL,HELLA DRIVING LIGHTS , LEVELING KIT,SEMI DEBADGED,SUNDOWN 100.2 AMP,TECH 12 PORTED BOX W/ 2 -10'S.(AMP , SUBS AND BOX WON IN 12 VOLT TECH RAFFLE, THANKS TECH AND SUNDOWN AUDIO)
drg titan is offline   Reply With Quote
Old 08-29-2008, 12:11 PM   #9 (permalink)
SlidinS14's Avatar
Originally Posted by drg titan View Post
Attachment 64900Hey, i had my sat. receiver there and i moved it to the overhead console.What do you think?
This is exactly what I have thought about doin to mine as well. I did an install to my 240sx that took the place of one of my DIN openings. It is perfectly clean.
SlidinS14 is offline   Reply With Quote
Old 09-03-2008, 08:48 AM   #10 (permalink)
LOL...over 3 months w/o a comment on this post, then BOOM!
Anyway, does anyone know if there is a easy way to plug in to the back of the panel like described above, but retain the use of the aux jack from the outside? I'd need to be able to plug my Ipod in when not using the Sirius.
Garmin Nuvi 200
Old 09-03-2008, 08:51 AM   #11 (permalink)
You would have to splice in a second jack to the wiring in the back with a switch to switch between the two.. Wouldn't be too hard to do.
Old 09-03-2008, 09:08 AM   #12 (permalink)
drg titan's Avatar
i used a p.e.i that plugs into the wires on the back of the r.f. stereo.It gives me two inputs that are controlled by the aux. button on the radio.they are conned directly w/rca inputs.
Old 09-03-2008, 11:08 AM   #13 (permalink)
I plan to mount my Starmate above the compass and temp display. I will post pics of the final installation.
Craig Brickner
Toy Toe'r = 2007 Titan LE CC 4x4 Galaxy/Grey
Track Toy
Car54 is offline   Reply With Quote
Old 09-03-2008, 11:09 AM   #14 (permalink)
Mix-It Products
Craig Brickner
Track Toy
Old 09-03-2008, 11:39 AM   #15 (permalink)
TitanOwnr's Avatar
Send a message via AIM to TitanOwnr
I spliced in to the AUX behind the panel for my Sirius tuner. When you plug in your Ipod, just turn the Sirius tuner off and your Ipod sounds fantastic.
TitanOwnr is offline   Reply With Quote
Sirius Install P-Kidd Titan Visual & Audio Discussion 1 01-07-2008 03:19 AM
A different Sirius PNP install. luvbelly Titan Visual & Audio Discussion 4 10-18-2007 05:32 PM
Sirius Streamer GT install with pics TitanDaddy Titan Visual & Audio Discussion 10 07-23-2006 07:41 PM
Sirius install jkiller5150 Titan Parts & Accessories 23 09-20-2005 07:05 AM
My Sirius Install raxton Titan Interior Discussion 27 12-06-2004 05:33 PM
