Old 05-16-2008, 06:04 PM   #1 (permalink)
Dirty06LE's Avatar
RF A/F Headunit install wire colors HELP
I'm tryin to hook up and aftermarket Pioneer heaeunit in my 06 LE with the Rockford Fosgate original unit. Does anyone know the colors of the speaker wires? They seem to be different than all of the threads i looked at on this site. Any replies would be greatfully appreciated.
Dirty06LE is offline   Reply With Quote
Old 05-16-2008, 06:51 PM   #2 (permalink)
Re: RF A/F Headunit install wire colors HELP
Are you aware the RF system uses an external amp? You can bypass the amp and use the standard wiring adapter to wire your HU such that it will plug into the dash harness. The wiring adapter includes wire identification for wiring to your HU.
I have written several posts on how to bypass the RF amp. Do a search on my screen name.
Old 05-18-2008, 08:55 AM   #3 (permalink)
Dirty06LE's Avatar
Well i figured out my problem. The remote wire off of the new headunit needed to be spliced in with the green/white wire from the factory harness and also with the subwoofer amp remote. Works great now, but i'm getting a nasty "popping" sound out of my speakers whenever i switch sources on the HU. I was told this is because of the stock amp still being hooked up. I would like to bypass the factory amp but i think i will leave it alone until i can get it to an audio shop and let them do it.
OEM speaker wire colors drosch Titan Visual & Audio Discussion 3 03-30-2006 07:44 PM
What's the difference in wire colors??? tijoseph Titan General Discussion 9 08-04-2005 07:01 PM
Help with wire colors at rear harness HudsonValleyTitan Titan General Discussion 2 01-20-2005 10:23 PM
Speaker Wire Colors ? PoohDaddy Titan Interior Discussion 2 12-15-2004 09:14 AM
stereo wire colors piopremier Titan General Discussion 5 12-15-2004 09:09 AM
