Go Back   Nissan Titan Forums > Titan Discussion > Titan Visual & Audio Discussion
User Name
Password
will these subs fit? - being discussed at Nissan Titan Forums in the Titan Visual & Audio Discussion section.
Old 05-18-2008, 08:08 AM   #1
deepwatertitan
deepwatertitan's Avatar
Question will these subs fit?
anyone know if you can fit 2 jl audio 13" w3's will fit under the rear seats of a crew cab?i can get a good deal them...if two wont fit what about just one?i really want them cuz my buddy has four in a trailblazer and its hard to even sit in his truck(hurts my ears).thanks.
deepwatertitan is offline   Reply With Quote
Old 05-18-2008, 08:20 AM   #2
tech12volt
Supporting Vendor (Gold)
tech12volt's Avatar
Re: will these subs fit?
Not without one hell of a seatlift and I doubt you could get them in then. They are a way to deep
Please check out www.tech12volts.com
tech12volt is online now   Reply With Quote
Old 05-18-2008, 08:30 AM   #3
deepwatertitan
i didnt think so.to bad cuz i can two of them for a 100 bucks and detail his paint.hell there 300 a peice new.i was pretty sure they woudlnt fit though.still might get them and sell um for more or do something with um
Old 05-19-2008, 04:13 AM   #4
t22a80
t22a80's Avatar
Send a message via AIM to t22a80
Take them for 100 bucks and sell them there are many audio forums you could sell them on or even craigslist. Then buy a box with subs from Tech12Volts! That would be your best option!
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
t22a80 is offline   Reply With Quote
Old 05-20-2008, 04:58 PM   #5
deepwatertitan
they may fit!!!one of are local sterio guys said that he can fit them under the seat,and build it to spec.since these are w3's they are not much deeper than 12's.this guy is a pro and deals in these subs.here are some pics he did in my buddies trailblazer and these are the same subs i am buying.hes taking these out to build a wall to hold his 18" sub and add more amps.that amp you see there are three more behind it and he is adding 2 or three more.you can hardly sit in this thing as it is.
Click image for larger version
ID:	61385  Click image for larger version
ID:	61386  Click image for larger version
Old 05-20-2008, 05:44 PM   #6
deepwatertitan
i do still have my doubts and am going saturday to have the guy double check.if they wont fit then ill just focus on getting my rims and tires
Old 05-27-2008, 08:56 PM   #7
boost_junkie21
I don't see why they wouldn't fit. I just installed 2 pioneer premier 12's in a ported box under my CC back seat without a seat lift.. It took a good bit of planning and some fiberglass work but def worth the effort. These things freaking POUND!!! I'll get some pics of the install up once the wiring is cleaned up and the trim panels are finished.
boost_junkie21 is offline   Reply With Quote
Old 05-27-2008, 09:51 PM   #8
SeahawksTitan
SeahawksTitan's Avatar
Hey deepwater...Is that the new "BullyDog" mod you have up by the drivers seat in that second pic?
__________________________
2006 Smoke Titan XE 2WD KingCab
Lucky Seahawks Antenna Ball
17" ATX Predator Teflon wheels
Bakflip bed cover (soon!)
SeahawksTitan is offline   Reply With Quote
Old 05-28-2008, 03:18 PM   #9
Warp09
I have 2 12 W3s in my truck, and they stick out. SO, 13s will stick out a lot more!!!!
2006 LE Galaxy Black 4WD BT Fully Loaded
IRC VK56 Member
Best 1/8: R/T - .041, 60' - 2.094, E.T. - 9.516 @ 71.91 (pre-tuned)
New times coming soon!
Modifications: S&B CAI, Custom Magnaflow Exhaust, Custom tuned by Church Automotive (UpRev Software), 6000k HID Fogs, Silverstars in High/Low Beams, Alpine PDX 1000, Custom Box, 3 JL 12" W3s, Alpine CDA 9851 HU, Debadged
Warp09 is offline   Reply With Quote
Old 05-28-2008, 03:48 PM   #10
deepwatertitan
thats the top of the line security right there..lol..id really like to see some of you guys pics of the sterios with 12"s.the guys shop was closed last sat but i may just go with 12's if they wont fit.
Old 05-28-2008, 04:17 PM   #11
tech12volt
tech12volt's Avatar
PIONEER SLIM 12s i would assume. Please post pics of this.
Old 05-28-2008, 05:47 PM   #12
boost_junkie21
No they weren't the slims. They were the older "carbon fiber" cone premieres. I don't have all the specs bc a friend that build the boxes at the local stereo shop did most of the fab work. I'll have to post some pics when i get home, just came out for my 2 weeks offshore.
User Name
Password
New JL subs out PhatLykThat22 Titan Visual & Audio Discussion 5 04-23-2008 10:14 AM
looking for subs Stevon Titan Visual & Audio Discussion 1 03-08-2008 03:30 PM
subs for box Foglght Titan Visual & Audio Discussion 6 11-30-2006 04:29 PM
subs help biznutz Titan Visual & Audio Discussion 3 11-19-2006 06:49 PM
What sub box - subs are you using for CC Methu969 Titan Visual & Audio Discussion 11 07-11-2005 04:27 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
