Some time last week the factory installed Sirius radio in my 07 LE stopped working.
On the LCD display all I see is "Acquiring Signal" when I tune to Sirius. I took it to the dealership for a service and they said they could find nothing wrong, which I am inclined not to believe. I also called Sirius to ensure that the subscription was still active.
I thought about sending an activiation signal to the radio once again, but there is a problem. I cant actually change the channel on the Sirius radio, so I cant get to 184, or even channel 1 to get the SID. So the radio is pretty much useless.
Has anyone seen a problem like this before?
__________________ 2007 Nissan Titan LE Crew Cab - Galaxy Black
Sirius Satellite Radio, Bed Divider, Bed Extender, Tow Package, Navigation Package, Step Rails, Hood Protector, Compustar 2-way Remote Starter.
One thing to try is to remove power from the receiver. It should be located under the dash just above the brake pedal. There is a white plug that provides power to the unit. Pull that plug and leave it out for 30 seconds or so, then plug it in. While you are there make sure the antenna connection is solid.
My XM radio has done this several times. The only thing I've found is if I insert the key and turn the truck on really quickly I have the issue. I as if turning the truck on somehow interrupts the HU intialization procedure.
Usually when this happens if I change to channel 0 to see my Radio ID it's blank. This seems to be a bootup problem - of course the dealer has never heard of this problem before.
Anyway, turning the truck off and removing the key then restarting it (slower) seems to resolve the issue.
2008 4X4 Se CC LWB "Timberline", Popular Package with Captain Chairs, Big Tow, 1Start remote starter, 2* Timing Advance, Westin Sure-Grip Side Steps, Active Tuning, Bed Extender, M&D Dvd & Monitor, Oem Hood Protector, OEM Bed Extender, Vent Visors, HotShot Wiper Fluid Heater, HID conversion, Line of Fire LED bar, OEM Nav Bezel, Garmin Street Pilot 7500, and Boyo VTL350 Backup Camera, Leer 100R Truck Cap, RoadMaster Active Suspension, and 2 Nissan Titan Hats
If it was factory installed, Sirius should be able to look it up via you VIN number I think, also the ID might be on your window sticker from your truck. Also, since you have an account with them, it should be on the account, it is also linked to your phone number...give them a call they should be able to fix it.
This has happened on my wife's jeep and we had to have the signal resent, fixed it
I have problems constantly losing XM signal- I have a factory installed XM, crew cab 04 with sunroof. Antenna is on back window with a swivel hinge and does not go above roof line but about 1-2 inches - I think antenna is bad- any suggestions for a replacement and or new location
I had the same problem with mine when I initially installed it into my '07. It worked long enough for me to get it activated and use it for about 30 minutes. Then when I started the truck back up it just sat on "Acquiring". I had Sirius send the signal to the unit and that did not help anything. I then tried another antenna hoping it would be that since that was the easier piece to replace and that made no difference. The dealership gave me a replacement tuner as that was the only other piece to replace and that took care of the problem. In my case the guy at the Parts Dept at the dealership was very good to deal with as he got me the replacement parts with no hassle.
If this is on an SIR-PNR2 tuner then you are probably going to have issues at some point. I know I did with mine and I went through 3 of these types of tuners. They were all grounded properly, everything was as it should be but the boxes kept burning up, and blowing fuses. The SIR-PNR2 has been discontinued.However, the new updated tuner is FINALLY available. Mine has been on backorder since April, so the wait is finally over. Here is a link to where I bought mine from. It really is a good deal too. In fact I bought all of my stuff from these guys. They will treat ya right, and the prices are some of the best I have seen.
"If you know the enemy and know yourself, you need not fear the result of a hundred battles. If you know yourself but not the enemy, for every victory gained you will also suffer a defeat. If you know neither the enemy nor yourself, you will succumb in every battle."
- Sun Tzu
2007 Nissan Titan SE King Cab
Born: October 6, 2006
Mine: October 16, 2006 Mods & Add-ons Post-purchase
Magnaflow dual exhaust w/ 31/2" chrome tips, OEM fog lamps, OEM splash guards, K&N FIPK Generation II cold air intake, Rhino-Linings bedliner(Tuff Stuff), Steering Wheel Volume Controls, VentVisor shades, Westin Oval Chrome Step-Rails, Chrome mirror covers, chrome tailgate bezel. Audio/Video
Pioneer Avic-Z2, 2 JL 10W3's on a JL 500/1, and 2 sets of Alpine SPX-17REF's on an Alpine PDX-4.100. Planned Add-ons
Bed Cover
