Old 07-05-2008, 02:33 AM   #1 (permalink)
subwoofer ad on
i am wondering if it is possible to run a line output converter off of the factory subwoofer wireing while retaining the factor sub or will this change the ohm rating to the amp?
08redpro4x is offline   Reply With Quote
Old 07-05-2008, 04:11 AM   #2 (permalink)
Blackbeauty's Avatar
Re: subwoofer ad on
You can do this, just don't expect that to drive another sub.... You still need an amp. And the power from the rear of the center console is a bit easier to tap into.
AKA: Cheap Whore™
IT'S ALL MY FAULT!
Pit Crew Chief
Old 07-05-2008, 09:50 AM   #3 (permalink)
Re: subwoofer ad on
well i know i need another amp and why would i steal power from the rear of the console and not the battery
Old 07-05-2008, 09:51 AM   #4 (permalink)
Re: subwoofer ad on
also does any body know where the factory amp is located and which wire is the turn on lead
Old 07-06-2008, 07:50 AM   #5 (permalink)
Timmyo2L's Avatar
Re: subwoofer ad on
I tapped into the rear cig outlet for a turn on, closer and easier.
also used this loc.. ne-774v http://www.davidnavone.com/cart.asp?24&cat=7
worked great.
Timmyo2L is offline   Reply With Quote
Subwoofer EJD1984 Titan Parts & Accessories 2 06-05-2007 09:57 AM
Best Subwoofer Set up!!! eduardomi Titan Visual & Audio Discussion 7 02-26-2007 07:34 PM
subwoofer popping streetrod777 Titan Visual & Audio Discussion 2 07-31-2006 10:04 PM
Subwoofer box?? Methu969 Titan Visual & Audio Discussion 4 06-17-2005 10:34 AM
Subwoofer pop radiokid Titan General Discussion 4 07-13-2004 05:40 PM
