Old 07-07-2008, 02:52 AM   #1 (permalink)
Speaker wires
I've just purchased new speakers (Pioneer) for my 08 Titan and I'd like to make the install as simple as possible I'd like to use the existing wires. How can I determine which wire goes to the + terminal and which is - ? Does it matter?
MrCoolDu4 is offline   Reply With Quote
Old 07-07-2008, 06:00 AM   #2 (permalink)
TitanBlue's Avatar
Re: Speaker wires
The OEM Speakers should have a + or - at each connection.
Yes, it is critical to get the Polarity correct. This is called Phasing.
You will not damage the Speaker if it is backwards, but the Phase will be wrong and you will not hear the music be centered like it should be. It will seem to float around or be weak. basically, the speakers would be going the wrong direction of their in/out motion, compared to another speaker making the same sound, and it just sounds awful, or like it isn't working.
DYNO: 308 RWHP & 380 RWTQ
~CRANK: 360 HP & 450 TQ
Born June 12, 2006
Adopted June 27, 2006
Old 07-07-2008, 03:55 PM   #3 (permalink)
Peytons_Titan08's Avatar
Re: Speaker wires
just went through this myself. none of the speakers are marked, they each have a different color. i got this list from crutchfield.
FUNCTION
PIN
WIRE COLOR
Accessory 12 Volt
1
VT
Constant 12 Volt
7
YW
Chassis Ground
BODY
Power Antenna
Remote
Illumination
5
PK/BK
Dimmer
RD/BU
FUSE VALUE
FUSE LABEL
FUSEBOX LOCATION
10 AMP
"AUDIO"
PASSENGER SIDE DASH PANEL
20 AMP
#31
PASSENGER SIDE UNDER HOOD
The dash tweeters are wired in parallel with the front door woofers.
In CrewCab models, the rear door tweeters are wired in parallel with the rear door woofers.
If the vehicle has rear seat audio controls w/ AUX input, both will be lost when an aftermarket stereo is installed.
Left Front Spkr +
4
BU/WT
Left Front Spkr -
10
BU/RD
Right Front Spkr +
3
WT/BK
Right Front Spkr -
9
BU/BK
Left Rear Spkr +
14
L.BU
Left Rear Spkr -
15
BK/YW
Right Rear Spkr +
11
OG/BU
Right Rear Spkr -
13
RD/BU
if this is confusing let me know and i can email you the diagram
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
FabTech Light bar w/9" Lights
Performance:
K&N CAI
Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3
Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black/Red Ballistic Offroad Jesters wrapped in 325/65 Terra Grapplers.
"LIFE IS GOOD"
Peytons_Titan08 is offline   Reply With Quote
Vtr Wires? riles Titan Visual & Audio Discussion 1 04-10-2007 12:39 PM
Help with Speaker wires Please! Deth Blooms Titan Visual & Audio Discussion 6 12-30-2006 07:07 PM
finding speaker wires for high level input baker2406 Titan Visual & Audio Discussion 5 01-31-2006 02:59 PM
Wires? CLASH4X4 Titan General Discussion 19 09-11-2004 03:12 PM
