how much power wire is needed to go from battery to rear seats in a KC? also i have usually put the fuse under the hood but does it matter where you put it or does it need to be a certain distance from battery or amp? was going to mount it inside the truck.
2008 Titan XE KC Exterior:
DeBadged
6000k HID Performance:
K&N CAI Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3 Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black XD Monsters wrapped in 325/65 Terra Grapplers.
Fuse placement doesnt really matter, as long as its on the power wire. As far as how much wire you need, it depends on how you are going to run it, and which side of the truck you put the amp on.
2007 SE CC 4x4 Off-Road Big Tow Galaxy Black,
Flowmaster Custom Dual Exhaust,
2 JL audio w7 10" Subs,
Custom Fabricated Intake With K&N Filter,
De-Badged,
Much more to come!
I think I bought 20' of power cable for mine and I had plenty. I also ran it through firewall on the passenger side. The amp is mounted under the passenger front seat.
The fuse needs to close to the battery.
ZlacherWhore™
Why is there never enough time to do it right the first time,
But always enough time to do it again?
thats alot of wire, how much did you have to cut off? since its only under the passenger seat
2005 Deep Water Blue KC XE
Performance Mods: BullyDog Power Pup, 18" MagnaFlow Muffler Stock Pipes, K&N CAI
Exterior: 22" Dub Bully II, Kumho Tires, Rear Leaf Removal/Drop Shackle, Armada Air Dam/Step Rails, Painted Door Handles, Headlight Mod, 8000k HID's L.B., Smoked Tail Lights, Custom Painted Grille
De-Badged,
Much more to come!
You should put the main fuse as close to the battery as possible. I think its supposed to be between 12" and 18" from the battery. I'm not positive on the exact number though because I usually buy the kits that are all pre cut for this.
