07-08-2008, 05:33 PM
#1 (permalink )
installed system now reuck wont start, headlights come on but stereo plays?
ths is beyond me? anyone have a suggestion? thanks
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3
Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black/Red Ballistic Offroad Jesters wrapped in 325/65 Terra Grapplers.
"LIFE IS GOOD"
07-08-2008, 06:18 PM
#2 (permalink )
Supporting Vendor (Gold)
Re: installed system now reuck wont start, headlights come on but stereo plays?
Did you beat on anything maybe a fuel pump reset. No clue man. I would need to know what all you took apart
Please check out
www.tech12volts.com
07-08-2008, 06:39 PM
#3 (permalink )
Were you in the engine compartment?
A disconnected ground for the main engine harness will cause this problem with your reuck.
My
has almost nothing compared to some of you guys, but I still like it.
MADE IN USA is the way things are supposed to be.
ACCEPT NO SUBSTITUTES .
And if you have to, you have to.
Wallee AKA BaldWhore™
You know you had a great night last night when you make it home the next day missing at least 1/2 of your clothes.
07-08-2008, 06:40 PM
#4 (permalink )
the only thing i did was this:
take the dash kit off, install the rca's abd remote lead. ran that to the amp.
hooked up the ground
drilled a hole in the fire wall for power
hooked up the power to the terminal and amp then put the fuse in the holder
turned on the stereo and listened to it for a sec and forgot i had hooked up the rca's backwards turned the key off, switched them then heard the sub then tried to turn the truck on and nothing. never seen this.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
07-08-2008, 06:41 PM
#5 (permalink )
dont know how i could have done that but how do i fix it?
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
07-08-2008, 06:42 PM
#6 (permalink )
Did you check your fuse box?
AKA: Critter Whore™
07-08-2008, 06:44 PM
#7 (permalink )
Well if you weren't messing with any of the engine wiring harness under the hood, that is likely NOT the problem.
Are you missing, say a big wire off the battery cable?
My
07-08-2008, 06:50 PM
#8 (permalink )
umm no, everything but the dome light and truck run.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
07-08-2008, 06:59 PM
#9 (permalink )
for a sec i was like "wtf is reuck?" nice one.
i was in there to run the power cable.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
07-08-2008, 07:07 PM
#10 (permalink )
When you drilled through the firewall, were there any obstructions in the way? There are a lot of important wires routed along the firewall. Just an idea to chew on. Good luck Peyton!
iWhore™
AKA BUDWhore™
IRC VK56 Member " Pit Crew Chief "
07-08-2008, 07:23 PM
#11 (permalink )
went right to the wheel well, are there any wires under the drives floor panal? thats where i ran the rca's and remote.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
07-08-2008, 07:25 PM
#12 (permalink )
If the domelight does not work check all of your fuses.
Please check out
www.tech12volts.com
07-08-2008, 07:26 PM
#13 (permalink )
I tried to tell him that earlier, mabye his model reuck doesn't have those.
AKA: Critter Whore™
07-08-2008, 07:33 PM
#14 (permalink )
i did but will do it again, this d@mn reuck is pissing me off. lol
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
Suspension/Wheels:
"LIFE IS GOOD"
07-08-2008, 07:40 PM
#15 (permalink )
Did you check your spelling ?.....LOL
................................... BEERWHORE™.....................................
"THIS TRUCK IS AWESOME" !!!!!!!!
2004-LE-CC-BT-OR-4X4-w/VDC-Utilitrac-Pearl White (THE BEAST)!!!!
2* advance, Volant CAI, TBS, Flowmaster 40 series w/4" duel tips, Bilsteins, Weathertech floormats, Okole seat covers, Westin Bullbar w/KC Lights
Display Modes
Rate This Thread
Linear Mode
