Old 03-28-2009, 05:53 PM   #1 (permalink)
drpeeb's Avatar
Remove rear door panels, how?
I want to replace the rear speakers in my '05 King Cab. I've got the speaker cover off but don't see any screws. Please help!
(I know replacing the rear speakers won't help much alone; I'm going to run my iPod into an amp that power new rear speakers plus a sub. Not gonna mess with the HU or front speakers at all - Just turning it off!)
Can't seem to find the answer here anywhere ... Thank you!
drpeeb is offline   Reply With Quote
Old 03-28-2009, 05:57 PM   #2 (permalink)
Banned
Re: Remove rear door panels, how?
I hope someone chimes in.. You're a king cab, right?
I'm putting this on my favorites incase I need to do the same!
adamdude04 is offline   Reply With Quote
Old 03-28-2009, 10:39 PM   #3 (permalink)
drpeeb's Avatar
Bump ... Anybody? Pleeeease?!! I'm ready to take 'em off, but don't even know which way to pull, push, yank, twist ...
I see lots of talk about the front door panels, but not the rear ...
Old 04-04-2009, 10:38 AM   #4 (permalink)
I'm also an 05 king cab and I've been looking for the same thing and here's what I found.
Go to All About Nissan and register. Theres no fees or anything like that, and the only info that it wants from you is an email address.
Once you're registered and signed in go to the knowledgebase and then go to the recalls/campaigns. It then has you pick the vehicle and year. Next is the list of recalls. The 2nd one is VOLUNTARY RECALL CAMPAIGN 2004–2006 NISSAN TITAN REAR DOOR HARNESS. Click on the NTB07-009 and open the PDF. The PDF has photos of how to take apart most of the interior.
drr82 is offline   Reply With Quote
Old 04-05-2009, 10:22 AM   #5 (permalink)
Peytons_Titan08's Avatar
getting the rear door off is easy. you have to remove the seatbelt and just pull out. there are a lot of tabs holding it on. once you pop all the tabs it just falls right off. dont be scared to pull its hard to break. im taking my rear speakers out soon so ill post the how to.
TRUCK IF FOREVER CHANGING! check back
"LIFE IS GOOD"
Peytons_Titan08 is offline   Reply With Quote
Removing door panels jason27 Titan FAQ & Howto Area 4 05-21-2006 09:53 PM
door panels apronman_dan Titan FAQ & Howto Area 1 06-12-2005 09:40 AM
Hwo do these Door Panels come off biggieb22 Titan Interior Discussion 4 05-20-2005 11:12 AM
How do I remove door panels? DaveS Titan Interior Discussion 3 01-24-2005 10:52 AM
how to remove door panels??? aznsupra Titan General Discussion 1 11-01-2004 07:37 AM
