The Installation: Blackbeauty NEVER Sounded So Good! - Nissan Titan Forum
Old 03-31-2009, 11:33 AM   #1 (permalink)
Blackbeauty's Avatar
iTrader Score: 9 reviews
Sorry for the wait, but it's been a bit hectic since the installation. But now, without further ado, here are the installation pics.
I arrived at tech12volt's place on Sunday, March 8, as planned. Due to a recent bout with a nasty virus, his whole family was under the weather that weekend, so we didn't get to the Titan until Tuesday. But she was in "The Shop" and preparations were being made.
Before the installation, as you may or may not know, I had the JL Audio 300/2 amp pushing the JL 10" sub in the first sub box that tech ever raffled. I thought it sounded pretty good... Well, I didn't really know "pretty good"...
The rest of the interior was stock....
We got to tearing out the interior... Seats, trim, rear wall, but weren't really removing the carpeting yet. The plan was to just sound deaden the doors.....
We had to remove the factory NAV DVD player under the passenger's seat as well as the factory R/F sub under the driver's seat.
The center console cover came off, and we figured we were just about done with the teardown....
And now... The goodies... All CDT products! Audiophiles unite!
Viper 7900 Car Alarm and Remote Start:
Many have already seen the nightmare of wiring that tech had to navigate to install this. It went well and works flawlessly. He really made this look easy.
Kenwood CCD-2000 Universal Rear View Camera:
This was mounted on the rear hitch (which I had Line-X'd just prior to hitting the road to tech's place - that's Mystery Mod #2.) The wiring was run inside the frame rail under the truck.
Next, the doors were stripped and they were sound deadened.
Once that was completed, the rear wall was sound deadened....
But... inspiration struck, and the thought to sound deaden the floor also, which was tossed around multiple times, finally came to fruition... So, the center console had to come out along with the carpet.
Then the floor sound deadening continued....
Adapters were made for the front and rear door comps. They were then covered with spray on truck bedliner to prevent the MDF from deteriorating from moisture when in the doors.
The comps installed were CDT ES-62iUS GOLD comps with the Braxial tweeter mounts for the front.
The StageFront technology was used and additional CDT DRT-26 1" tweeters were installed in the front A-pillars. This StageFront system brings the sound from down at your knees, up to the level of the top of the dashboard. You feel like you have front row seats at a concert the way the sound hits right in front of you. It's seriously, an incredible upgrade that is WELL worth the money.
The CDT CL-62 comps were installed in the rear doors since I didn't want any part of this system to be weak.
All the sound system wires were run, zip-tied, and tucked away so the carpet could be reinstalled.
That done, the interior started going back together slowly. The center console was set in place and the TVandNAV2Go was wired up and installed so I could not only have the rear backup camera on the NAV screen, but also play the movies from the factory DVD system on the NAV screen as well. These were all run through the toggle switches on the center console and in the console storage tray so I have full access to all features all the time.
The first time we turned the backup camera on to test it... guess what....
Yup... it was upside down. Hey... I defy anyone to be able to tell which way the camera needs to be pointed... There's no markings on it! A quick switcharoo of the camera on the mount and we were in business...
The factory NAV DVD player was reinstalled on the floor and the interior was put back together.
Meanwhile, a small pedestal was made for the controls... Peripheral's PCH8 8-Channel Line Out Converter was chosen to push the signal from the stock headunit (That's right! This system sounds THIS incredible with the STOCK R/F HEADUNIT!) to the amps and control all the speakers.
The front comps run through the CDT StageFront ES-200US Crossovers while the rear comps run through the CDT EX-480 Crossovers. These are all mounted under the passenger rear seat.
Powering the subs and comps are the CDT SQA-4100 Amps. These sleek beauties can push 110W x 4Ch, 150W x 4Ch, or 300W x 2Ch depending on your setup and what you need. They were mounted to some amp racks hidden behind the rear seats. As usual, tech did a masterful job of carpeting the support for the PCH8 and the amps.
Once all buttoned up, the sub control switch was mounted inside the center console, within easy reach for instant sound adjustments.
With the truck's interior all back together, it was time to head back into the wood shop and fab up the custom Blackbeauty Sub Box. The box was built, resined, sealed, sanded, and perfect before any vinyl was wrapped.
The raised letters were added and the vinyl was stretched on it to cover all visible surfaces.
The (4) CDT EF-100 10" Subs were then fitted and the box was set under the seat in the truck.
After testing, the box was filled with polyfill to tighten up the bass even more than it already was. This thing sounds incredible. It can hit at all volume levels and the sound in the cabin is exceptional. You literally cannot tell where each aspect of the music is coming from. It all sounds like it is right in front and all around you. A better sounding system, I can't imagine. You really have to hear this to believe it!
And the best part... all this looks stock, is hidden, and out of range of roving eyes who might be looking to remove it from my possession....
While there, I had tech add a few other goodies.... We did the NAV Bypass so I can operate the NAV on the fly. Factory settings prohibit altering or setting the NAV destinations unless the truck is stopped.
The '08 Lighted Steering Wheel Audio/Cruise Controls were also installed.
Blackbeauty's OT Mystery Mod: Revealed!!!
In addition, the Stebel Air Horn got put on a toggle so it can be turned off for state inspection.
Also, to help the system and the electronics out a bit... I installed the Active Tune Grounding Kit.
I have to say, tech, Mrs. tech, and the four little tech's were just incredible hosts/hostesses through this whole install. I can't thank all of them enough for the hospitality, dedication, and kindness I was offered while staying there. I also can't say enough about tech and his skills with car audio/electrical systems. I saw things that would make an electrician shake his head.
It's been said hundreds of times, but trust me, I lived it... if you need any audio equipment or need installation, look no further. Now, you don't have to go nuts like I did, as there are dozens of options, packages, and systems to select based on need, desire and budget. But if you want it good and you want it right, tech12volt is THE MAN to talk to for all your audio needs. Just click the link labeled as such in my sig. You won't ever regret it!
Advertisement
Old 03-31-2009, 11:38 AM   #2 (permalink)
Banned
bbomar's Avatar
iTrader Score: 12 reviews
Re: The Installation: Blackbeauty NEVER Sounded So Good!
Nice Red X's
Old 03-31-2009, 11:41 AM   #3 (permalink)
Carbeaux's Avatar
iTrader Score: 6 reviews
Unreal. Absolutely unreal. Congrats on the upgrade.
Looks like an excellent install by Tech, too.
Hook 'Em Horns!
"Life is a tragedy to those who feel but a comedy to those who think"
-Horace Walpole
The Following User Says Thank You to Carbeaux For This Useful Post:
Blackbeauty (03-31-2009)
Old 03-31-2009, 11:45 AM   #4 (permalink)
Originally Posted by bbomar View Post
Nice Red X's
Well, when you step up and decide to live in the modern world... you can see the pics, too!
Old 03-31-2009, 11:47 AM   #5 (permalink)
bills1974's Avatar
Send a message via AIM to bills1974
It's amazing how much thought and work you guys put into everything. When you first told me you were going to be there for a week, I thought it would be impossible for it to take that long...after seeing all the work first hand that was put in and hearing it in person, I now know why...there was a lot of thought and sweat put into everything in there...
2008 Titan SE CC, Popular Package, Big Tow, Bed Utility Package, Sliding Bed Extender
Click here to see my mods
Click here to see my pics
Cowl Done With Bedliner
Radiator Bypassed - Transmission Fluid
Daily Ride: 2012 Nissan Juke SV 6MT
Wife's Ride: 2009 Infiniti G37 Coupe
My Other Ride: 2007 Sea Doo Speedster 200
AKA: Crossdresser Whore™
The Bald Avenger®
"Why is the rum always gone?"
bills1974 is offline   Reply With Quote
The Following User Says Thank You to bills1974 For This Useful Post:
Old 03-31-2009, 11:53 AM   #6 (permalink)
import2nr's Avatar
iTrader Score: 3 reviews
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
nice man .. very
Uprev Dyno Tuned 296hp 354tq 87 octane
*2004 Galaxy Black SE CC*
*Rockford Fosgate Punch 200 a4*
*One 10" Kicker Comp down firing*
*Omega MAX-E Remote Start/Alarm with pager remote*
*Spectre 4" CAI w/ Volant Air Box and Ram Air Scoop*
*Doug Thorley LT Tri Y's*
*Stillen B-pipes with Magnaflow cats (gutted)*
*Exhaust-Custom*
*Hoppy EasyLift Tailgate Lift Torsion Bar*
*Black Alteza style tail lights*
*NCD 2" Leveling Kit W/ Bump Stops*
*Ikon shocks with 1" block in the rear and Bilstein 5100's in the front ( adjusted to middle notch)*
*Michelin LTX A/T 2 ---285/65/18*
*Chrome Range Rover Fender Vents*
*18" Warrior Vision Wheels*
*EBC Slotted and dimpled front rotors*
import2nr is offline   Reply With Quote
The Following User Says Thank You to import2nr For This Useful Post:
Old 03-31-2009, 11:54 AM   #7 (permalink)
vilim12's Avatar
iTrader Score: 2 reviews
Thats literally amazing, theres no way anyone would ever be able to tell you have anything done to the sound system by just looking at it!
Looks like a truely great install im sure your enjoying it 10000X more than I am enjoying looking at the pics lol
Maybe A video for us?
2008 Nissan Titan Pro-4x CC LWB Smoke
MODS LIST BELOW
http://www.titantalk.com/forums/2633776-post773.html
vilim12 is offline   Reply With Quote
The Following User Says Thank You to vilim12 For This Useful Post:
Old 03-31-2009, 11:59 AM   #8 (permalink)
DeadRiver's Avatar
iTrader Score: 4 reviews
Send a message via AIM to DeadRiver
Great install..... I've already left my thoughts in the other Blackbeauty threads and won't regurgitate them again!!! Awesome is an understatement!
Did your dashboard throw up from the Virus too
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
I should stop having my suit dry cleaned, it seems to kill people.
The Urinator™
DeadRiver is offline   Reply With Quote
The Following User Says Thank You to DeadRiver For This Useful Post:
Old 03-31-2009, 12:06 PM   #9 (permalink)
vilim12's Avatar
It looks like a bunch of racoons made their way with the dashboard one night, id throw up if i saw my wires everywhere like that.
MODS LIST BELOW
Old 03-31-2009, 12:06 PM   #10 (permalink)
undy's Avatar
Incredible, makes me feel that I need to do a major face lift on my system. Personal favorite is the toggle switches installed, looking at that alone tells you how clean the rest of the work is. I need a tech12 in Cali.
undy is offline   Reply With Quote
The Following User Says Thank You to undy For This Useful Post:
Old 03-31-2009, 12:07 PM   #11 (permalink)
vilim12's Avatar
Your missing one thing BTW
Playstation 3 60GB with Rockband and Games LOW RESERVE - eBay (item 160324891159 end time Apr-05-09 10:38:28 PDT)
you could have your own Rockband in the bed!
MODS LIST BELOW
Old 03-31-2009, 12:07 PM   #12 (permalink)
I didn't video any of the install... But I can borrow DR's camera again and grab some vid/aud of the system in action... Won't do it justice, but I'll give it a shot next time I'm at his house!
Old 03-31-2009, 12:08 PM   #13 (permalink)
The DVD player has the S-Jacks to hook it up... It IS possible!
Old 03-31-2009, 12:13 PM   #14 (permalink)
Pops's Avatar
iTrader Score: 0 reviews
WOW!!! That's SWEET!!!!
2005 Armada LE 4x4
Pops is online now   Reply With Quote
The Following User Says Thank You to Pops For This Useful Post:
Old 03-31-2009, 12:13 PM   #15 (permalink)
bills1974's Avatar
What you need to hook up in there is a Wii. I want to see people flailing around in the back seat trying to bowl
The Bald Avenger®
Advertisement
Blackbeauty Naked!!!!! Part V: Return of Blackbeauty! Blackbeauty Titan Pictures & Media Post 48 01-25-2010 09:33 AM
Blackbeauty requests help from the Titan Community Blackbeauty Titan Problems & Dealer Service 18 05-27-2008 07:37 AM
Blackbeauty NAKED!?!?!?!?! Blackbeauty Titan Pictures & Media Post 44 05-08-2008 03:52 PM
Blackbeauty with Fall Foliage Blackbeauty Titan Pictures & Media Post 10 11-01-2007 10:42 PM
SEO by vBSEO 3.3.2
