Remove interior door panels? - Nissan Titan Forum
Old 07-08-2009, 03:17 PM   #1 (permalink)
iTrader Score: 0 reviews
I just laid out some sound deadener mats on the floor of my crew cab and I'm thinking about doing the same with the doors in my truck. How difficult would it be to access the inside of my doors? The main reason I'm doing this is to cut down on the noise from my mud grapplers. Insulating the floor actually cut down on a good portion of the noise, but it's still pretty annoying on the highway. I figured deadening the doors would make a significant contribution. What do y'all think?
$partacus is offline   Reply With Quote
Advertisement
Old 07-08-2009, 09:33 PM   #2 (permalink)
Supporting Vendor (Gold)
tech12volt's Avatar
iTrader Score: 30 reviews
Re: Remove interior door panels?
It will help as will the backwall and firewall
tech12volt is offline   Reply With Quote
The Following User Says Thank You to tech12volt For This Useful Post:
OneQuick06 (07-09-2009)
Old 07-08-2009, 09:41 PM   #3 (permalink)
FELIPON619's Avatar
its very easy i actually have my rear door panel off now,i just installed some new speakers....
FELIPON619 is offline   Reply With Quote
Old 07-09-2009, 02:46 AM   #4 (permalink)
BLBJBranch's Avatar
It's not too bad, but you have to be pretty careful. You have to remove several screw bolts (5 or 6 I think). They are under the rubber on the arm rest (pry the rubber cushion up and off the rest) and on the door pull handle (pry out with a small flathead), as well as one under a small pop out under the door latch.
You then have to pry the panel off by popping out the plastic rivets going around the panel.
Finally, you'll have to remove the connectors for the lock and window wires, as well as the cables for the lock and latch if you want to be able to completely remove the panel and place it elsewhere.
It's not too bad. Just kind of scary the first time.
2007 Titan Crew Cab 4x4 LE, Granite/Graphite, Tow Package, Chrome Package, Lund Deflector, K-Cover, Black Dunder V-Grill, Fly Rod Antenna, ScanGaugeII/Blendmount, Audiovox Rear-View Mirror/Camera, Dash Designs Dash Cover, XM Radio
BLBJBranch is offline   Reply With Quote
The Following User Says Thank You to BLBJBranch For This Useful Post:
tetonshaggy (11-07-2009)
Old 07-09-2009, 02:54 AM   #5 (permalink)
OneQuick06's Avatar
iTrader Score: 3 reviews
If you have the right tools, it's no bid deal. Caution and patience are your friend in this situation.
2006 Galaxy KC BT SE
Mods: Click here Pics: Click here
CrayolaWhore™
MonkeyPumperWhore™
Remember, no matter where you go, there you are
OneQuick06 is offline   Reply With Quote
Old 07-09-2009, 04:21 PM   #6 (permalink)
NathanH's Avatar
Its very easy. I just did it myself not too long ago. Only a couple of screws and then you have to pull the panel to unsnap the clips(not sure what they are exactly called) and thats it.
NathanH is offline   Reply With Quote
Old 08-01-2009, 07:38 AM   #7 (permalink)
Well, I did it. But I busted some stuff in the process. I broke the plastic peice that holds the metal ball for the door latch. I was able to fix it by placing a washer on top of the metal ball. The only thing I couldn't fix was the spring that puts tension on the door handle. It popped out when I took the door panel off, and I couldn't figure out where it goes, so I left it out. No big deal. Thanks for everyones help.
Old 08-04-2009, 03:20 PM   #8 (permalink)
I think you should try and figure out were it goes..
Yaboi is offline   Reply With Quote
Advertisement
How do I remove door panels? DaveS Titan Interior Discussion 5 12-10-2010 10:47 AM
Remove rear door panels, how? drpeeb Titan Visual & Audio Discussion 4 04-05-2009 09:22 AM
Remove rear door interior panels, how? drpeeb Titan Interior Discussion 2 04-02-2009 10:55 AM
What is best to clean interior door panels? mwheat Titan General Discussion 16 05-28-2005 06:46 PM
how to remove door panels??? aznsupra Titan General Discussion 1 11-01-2004 06:37 AM
SEO by vBSEO 3.3.2
