What is a "TPMS Valve Service Kit?" - Nissan Titan Forum
post #1 of 9 (permalink) Old 10-24-2009, 09:44 AM Thread Starter
Luckyontheducky's Avatar
iTrader Score: 0 reviews
I know it is the tire pressure monitoring system. Why do the tire people want to charge me $4.00/wheel for them? I just seen it on the estimate and have not had a chance to ask the tire people yet. Does anyone know what these are? Are they necessary or just more $$ to the tire store?
Thanks!
L
Luckyontheducky is offline
Advertisement
post #2 of 9 (permalink) Old 10-24-2009, 09:45 AM
Blackbeauty's Avatar
iTrader Score: 12 reviews
Re: What is a "TPMS Valve Service Kit?"
Usually, it's new O-ring seals for the stems... I know they need to be replaced once in a while...
Blackbeauty is offline
post #3 of 9 (permalink) Old 10-24-2009, 10:44 AM
SATXTITAN's Avatar
iTrader Score: 21 reviews
Yeah its the O rings they replace, or should replace. I believe Discount tire changes the O rings and the aluminum sleeve as well.
SATXTITAN is offline
post #4 of 9 (permalink) Old 10-24-2009, 10:45 AM
iTrader Score: 4 reviews
Yeah, typically its a new seal, as mentioned above. I would just pay the $4 and have them changed for piece of mind. Also, if your sensors are going in different wheels, the wheels may be shaped differently than the wheels they were in so the original o-ring may not seal right.
ricepow is offline
post #5 of 9 (permalink) Old 10-24-2009, 11:08 AM
TitanBlue's Avatar
iTrader Score: 3 reviews
NISSAN requires a New Seal and a New Nut as well. They are not reusable according to NISSAN. I keep 2 sets of Seals/Nuts and a spare TPMS in my truck all the time.
They are pretty inexpensive. If $4 covers both items per wheel, that is not bad. The Mechanics really would rather use regular Valve Stems, as the TPMS is so easy to break.
UPDATE -from my Federated Catalog:
Schrader/Bridgeport TPMS Service Packs include Cap, Core, Nut, Grommet.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
post #6 of 9 (permalink) Old 10-24-2009, 11:34 AM
I would do it for $4. If the seal goes bad it can create a very slow leak that is difficult to detect.
bestatchess is offline
post #7 of 9 (permalink) Old 10-24-2009, 12:23 PM
SATXTITAN's Avatar
I believe Discount charges about $7 per wheel for new o rings and sleeve.
post #8 of 9 (permalink) Old 10-25-2009, 09:03 AM
AZPRO4X's Avatar
iTrader Score: 8 reviews
I didn't get mine rebuilt and i dont have any problems.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
post #9 of 9 (permalink) Old 11-03-2009, 09:28 PM
Seanbaker68's Avatar
its one of those things that is not necessay but good for piece of mind. the TPMS sensors have rubber grommets at the base and on the nut that screws on the outside. they also use a better grade valve core that has a rubber grommet as well. the tpms rebuilds we use replace every part but the sensor itsself and also gives you a new valve cap. rubber of course breaks down over time and can lead to a leaking sensor so it is not a bad idea to do the rebuild and prevent this from happening. If it is an 09 or 08 model then the rings are most likely ok but if it is a few years old then I would definitely recommend it.
Seanbaker68 is offline
The Following User Says Thank You to Seanbaker68 For This Useful Post:
TitanBlue (11-04-2009)
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Putting on a PRG 2.5"/1" Mini Lift Kit; Which tires will fit on a stock 18" wheel? TennesseeTitan215 Titan General Discussion 3 10-08-2009 04:56 PM
PRG "Mini Lift" or "Leveling Kit" oktex88 Titan Suspension 8 03-03-2009 09:15 AM
Valve Cover Gasket causing my Titan to "Burn" oil !?!? Hellions Titan Engine, Transmission & Drivetrain 1 04-08-2008 08:20 AM
WTB: 4" or 6" 2WD lift kit new/used, 35" tires and 18" wheels Geologist Buy/Sell 3 04-03-2008 06:50 PM
Will "Fix a flat" ruin my TPMS? Machado7 Titan Wheels, Tires & Brakes 13 03-12-2008 11:04 PM
You may post new threads
You may post replies
