Re: Inner front brake pads smaller than outer?
Upon closer inspection, it appears that the pads are correct, but at some point in the near past they stopped contacting the rotor correctly, leaving a narrower swept area than they had been (took a closer look and can feel where they were contacting). Bizarre, never saw something like that before. Tried to remove the two large bolts that hold the calipers in place.....no luck. Thought I might break them off, given the force I was using on them. Never had a problem removing the caliper bolts from any other vehicle I've owned in the past. Managed to carefully apply a bit of penetrating oil when I had them backed out a bit, may give it a day or three and try again.
