Originally Posted by Smoke05
Looking to get the T new sneakers. How big can I go without rub issues with the BFG TKO's on the stock rims? I have a PRG minilift. What would be the correct size. Looking for the tires to be LT load range D or E. Thanks!
The 33.7" LT305/65R18 probably wouldn't rub with stock rims and a mini-lift. If they did, it would only be on the mud guards, and the fender liner ... not the pinch weld itself. But I think it will clear all of it, unless your alignment has the front wheels too far back, and you would probably want an alignment anyway with new tires.
BFG AT KO LT305/65R18E
