Re: Brake service on 2005 Titan - do it myself?
Took my Titan to the dealer to have them remove the #@!$#@! wheel lock on rear passenger wheel. Had them replace the locks on other wheels with standard lug nuts, too.
While they were at it, the replace my A/C fan free of charge - there was apparently a recall.
Technician is telling me that the rear pads and rotors look fine. Apparently there is "plenty of wear left on them". He wants me to do a "brake diagnostic" for $96. Says I should return the aftermarket rear pads and rotors (which I haven't yet been able to install due to the wheel lock issue earlier). As expected, he went on to try and scare me about using aftermarket parts.
I will say that after replacing the FRONT pads last night, the BRAKE and SLIP lights no longer come on. Also, I've noticed an increase in braking performance. The front pads were NOT worn down to the wear indicator, but replacing them definitely helping with braking performance nonetheless. Could there possibly be something else wrong with the braking system, or would I just be wasting $96?
I'm not sure what to do at this point. I don't have lots of extra money to spend.
Reason: clarification
