Old 11-05-2009, 01:01 PM   #1 (permalink)
leonag123's Avatar
Backspace/Offset help, please.
I have a 2wd '04 Titan with 2.5/1.5 mini lift and 325-60/18 Terra Grapplers on stock 18x8 LE rims.
I am looking to get a little wider rims to replace my stock rims that i have on the truck now.
The wheel i am looking at is:
18x9
6x5.5
Backspace: 4.75
Hubcentric
Offset: -6mm
Anybody know how much more these rims will stick out past the fender with the size of wheels that i have? Will I have some serious rubbbing issues with these rims? I am not afraid of doing the pinch weld mod if i have to. Would prefer not to, but no big deal if i do.
Thanks for any help.
'04 Titan SE CC 2wd
325/60/18 Nitto Grapplers
Stillen Aluminum Radiator
Bull Bar
Bilstein HD Shocks
Banks Monster Exhaust w/Zoomers Tip
Truxedo Bed Cover
2.5/1.5 PRG Mini Lift
leonag123 is offline   Reply With Quote
Old 11-05-2009, 04:30 PM   #2 (permalink)
NorCal 4x4's Avatar
Re: Backspace/Offset help, please.
They'll stick out 1.75" more than they do now, and rub a bunch. Turn your steering wheel so your current setup is closest to the fender liner at the rear of one of the front wheel wells. Now imagine them sticking out 1.75" more, or use something to place at the shoulder to stick out that much more.
You can make them fit with the pinch weld mod.
The Following User Says Thank You to NorCal 4x4 For This Useful Post:
leonag123 (11-06-2009)
Old 11-06-2009, 06:28 AM   #3 (permalink)
leonag123's Avatar
Thanks a lot. Looks like its time to get out the saw.
'04 Titan SE CC 2wd
Bull Bar
Bilstein HD Shocks
Truxedo Bed Cover
20x10 KMC Rockstars fit?? -25 offset 4.5 backspace g356gear Titan Wheels, Tires & Brakes 24 10-16-2009 03:03 PM
whats the stock 18" rim offset/backspace etc? papojengo Titan Wheels, Tires & Brakes 2 10-22-2008 03:49 PM
I want 20's with 1.5" wider over stock? What offset/backspace/tire&rim width works? mekoz Titan Wheels, Tires & Brakes 8 10-10-2008 12:23 AM
offset/backspace question redrocket16 Titan Wheels, Tires & Brakes 0 04-07-2008 07:16 PM
backspace/offset... AETitan Titan Wheels, Tires & Brakes 4 05-15-2007 10:34 PM
