Old 11-06-2009, 09:51 AM   #1 (permalink)
tr7
Adjustable camber bolts
I just purchased the adjustable camber bolt kit from PRG. I was wondering if anyone had any detailed intrustions on install.
I do NOT plan on trying to align the vehicle myself, but if I can save 2+ hours of shop time on these bolts that would be great. Greg at PRG said if you can install the leveling kit, which I did, this shouldn't be a problem. I just have no idea where to start on these bolts. Anyone?
tr7 is offline   Reply With Quote
Old 11-06-2009, 09:56 AM   #2 (permalink)
Re: Adjustable camber bolts
Look where the lower a-arm connects to the truck. There is a gold bolt, washer and nut. There are 2 of each on each side of the truck. Thats where they go. Remove the old replace with the new in the same fashion (direction). Just did some last week. Piece of cake.
ricepow is offline   Reply With Quote
Old 11-06-2009, 10:29 AM   #3 (permalink)
tr7
Happen to have any pics?
Thanks for the info though!
Old 11-06-2009, 06:03 PM   #4 (permalink)
Keep in mind of one thing. It may not be as simple as taking them out and putting new ones in. If your existing bolts are somewhat rusted, getting them out will not be easy. If they are rusted in, you are looking at hammering them out (do not hit a bunch, you will bend the bolt) or they could maybe be pressed out by a hand held press.
If they are really rusted, you are cutting the a-arms off with a sawzall and replacing them.
I see you are in Wisconsin, so you are exposed to salty roads in the winter. Depending on the age of your truck, you may have some rust build up. I also see that you are a 2005, so, good luck man. I am an 06 and my bolts were practically welded fast by rust.
If they are not rusted, piece of cake
Thanks,
Zack
06 KC 4X4 Off-Road Big Tow
Nismo CAI and Exhaust
2" NCD levelling kit
1-1/2" rear blocks
Bilstein HD's front
Bilstein 5125's rear
Infinity Sound
www.iamstruth.com
zkeys is offline   Reply With Quote
Old 11-06-2009, 07:10 PM   #5 (permalink)
Good thought. Never crossed my mind. Im in Vegas so these issues dont happen here.
Old 11-09-2009, 07:44 AM   #6 (permalink)
tr7
I'm not expecting too much rust. We just did the leveling kit and everything came apart really nice.
The truck is an 05, but I only have 28K on it. At least I am hoping everything will go well.
Thanks for all the advice.
Fixing camber without camber bolts??????? HELP damerowalex Titan Wheels, Tires & Brakes 10 08-25-2009 09:28 PM
Thumbs up for Camber Bolts SeahawksTitan Titan General Discussion 0 03-21-2009 04:42 PM
how many camber bolts do i need? Gonpostal Titan Suspension 4 06-07-2008 02:30 PM
What do Camber Bolts do? thebassn8tr Titan Suspension 16 03-08-2008 10:18 AM
installing camber bolts 06titancrewse Titan Suspension 3 01-30-2008 08:29 AM
