Brake problem - new rotors/pads = rotor heating up - Nissan Titan Forum
post #1 of 8 (permalink) Old 02-23-2010, 04:54 PM Thread Starter
iTrader Score: 1 reviews
Hey guys,
I just installed new rotors and pads on my Titan.
I am having a bit of a problem though. My right rear rotor is heating up badly.
I can jack the back end of the truck up and spin the tire back and forth by hand, but not freely. It appears the pads are touching the rotor slightly, enough to give that burnt break smell and to heat up the rotor so bad the wheel is hot.
I took everything back apart...pushed the piston back in freely.
But it still is doing the same thing???
ANY IDEAS???
Thanks guys!
SweetRide#111 is offline
Advertisement
post #2 of 8 (permalink) Old 02-23-2010, 05:04 PM
Walrus's Avatar
iTrader Score: 20 reviews
Re: Brake problem - new rotors/pads = rotor heating up
What is up with the park brake shoes?
BaldWhore
Starfishwhore
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing more than half your clothes.
It's not the zombies you have to watch out for. It's the stupid people.
Walrus is offline
post #3 of 8 (permalink) Old 02-23-2010, 05:06 PM
Slade8's Avatar
iTrader Score: 0 reviews
Talking Re: Brake problem - new rotors/pads = rotor heating up
I am wondering the same thing. During the past few weeks I could smell my brakes in the garage after normal driving on very cold days. For some reason the brakes were extremely hot.
TBONE
05 LE Big Tow,Belltech&Hellwig AntiSway,BDGT,ST shackles,4x4 coils, AEM CAI sealed, painted interior,Resonators gone-custom Flowmaster Super44 sideout dual tip,Black Rhinos sapi 20x9,HID35w6k lows&fogs,Armaden LED's everywhere,chrome rockguard,Armada air dam,TB bypass mod,07 intake manifold,09 rearend,Poweraid TBS, TB screen gone, polished TB intake,KeyFob mod.
Slade8 is offline
post #4 of 8 (permalink) Old 02-23-2010, 08:13 PM Thread Starter
Not exactly sure what you mean by park break shoes...I did check the parking break shoes and all is fine. It is clearly the pads catching.
WHEN YOU GUYS INSTALLED AFTERMARKET PADS DID YOU INSERT/INSTALL THE THIN METAL SPACER THAT SITS NEXT TO THE PAD. IT APPEARS TO NOT HAVE ENOUGH ROOM AS THE PISTON IS NEARLY "BOTTOMED" OUT. IT LOOKS AS IF I REMOVED THE TWO SPACERS, ONE ON EACH PADS, IT WOULD FREE UP ENOUGH ROOM???
ANY IDEAS ON THIS?
Thanks,
Caleb
post #5 of 8 (permalink) Old 02-23-2010, 09:04 PM
ALtitan's Avatar
Did you check the seal on the piston? I had one crack which allowed dirt in and the piston wouldn't back off properly, when it happened I had to wait for an hour for the wheel to cool down enough where I could take it off.
ALtitan is offline
post #6 of 8 (permalink) Old 02-23-2010, 09:29 PM
BBtruck's Avatar
iTrader Score: 6 reviews
Did you grease those slide pin bolts or checked if they were scarred or bent?
L
My Galaxy '05 XE 4x1 modest mods:
Bilsteins HD, PRG adj. shackles, PRG swaybar endlinks, Stillen front and rear swaybar, RAS, Stillen Rad, BD PP, S&B CAI, DT LT's, Berk MP, SS Zoomers catback, Mag-Hytec rear diff cover, CF dash kit.
"The guy who invented the first wheel was an idiot, the guy who invented the other three, he was a genius."
BBtruck is offline
post #7 of 8 (permalink) Old 02-24-2010, 09:01 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
I put on a new set of rotors and pads on my wife's vehicle. They heated up so much I couldn't touch the wheel. They were grinding too. The vendor replaced both the rotors and pads and all is fine now.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #8 of 8 (permalink) Old 02-25-2010, 05:57 AM
djdubuque's Avatar
Post Re: Brake problem - new rotors/pads = rotor heating up
I'm also in the same boat, I have the rotors and pads replaced under warranty (16k miles) and now I have to do it again at 36+K miles.
The dealer is now saying that it is driving habits.
Should I take it back or replace them myself? I've had my brake warning light come on and the Slip light.
djdubuque is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
need some good brake pads and rotors STING77 Titan Parts & Accessories 13 07-28-2010 11:59 AM
Brake Rotors and Pads craigcoble2000 Titan Wheels, Tires & Brakes 2 02-19-2010 09:12 PM
Brake pads or rotors??? dank78 Titan Wheels, Tires & Brakes 1 09-18-2008 02:36 PM
What brake rotors and pads? NismoTitan Titan Parts & Accessories 0 03-27-2007 04:23 AM
front brake rotor/caliper/pads fell apart!!! life_is_good Titan General Discussion 3 12-15-2006 08:16 AM
You may post new threads
You may post replies
