6inch lift need help with tires and rims - Nissan Titan Forum
post #1 of 9 (permalink) Old 03-11-2010, 04:38 PM Thread Starter
iTrader Score: 0 reviews
hey guys i've decided to go with the lift kit. i was gonna get 20x9 with a 35-12.50 but i'm thinking about going with a 20x10. i know it depends on the offset but would the 20x10's clear with no rubbing? also who's got tire recommendations
Titan _Special is offline
Advertisement
post #2 of 9 (permalink) Old 03-11-2010, 05:04 PM
NorCal 4x4's Avatar
iTrader Score: 4 reviews
Re: 6inch lift need help with tires and rims
What kind of lift are you getting? For example the CST bracket lifts and their 2wd 4" spindle lifts that some use with leveling kits, or coilovers to get 6", and the Rough Country UCA's can rub with wide tires at stock backspacing, so they need to be pushed out more, with smaller backspacings, which will cause rubbing at the pinch weld, Wider rims also cause the pinch weld rubbing, and 10" on a 6" lift will rub unless you want to run really short - really skinny tires.
My friend had pinch weld rubbing with 35x12.5 M/T tires on 9" width rims with 4.5" backspacing, on his 4x4 Titan with a Pro Comp stage 1 lift. Same setup with a 4" spindle lift on a 2wd, plus 2" spacer would rub worse, because bracket lifts like the PC stage 1, move the wheels forward by an inch, according to PRG.
NorCal 4x4 is offline
post #3 of 9 (permalink) Old 03-11-2010, 06:49 PM Thread Starter
its a 4wd the rough country 6" its what i can afford 1600 installed from my local shop it would be ok to have the 9" but i had 10" and the ride felt better with the 12.50 my buddy had the same truck lift and tires i did but with the 9" wheel and had a lot of wobble in his steering wheel but youthink the 20x10 with the 35-12.50 are going to rub
post #4 of 9 (permalink) Old 03-11-2010, 06:53 PM
T-Dog23's Avatar
iTrader Score: 1 reviews
They will fit... thats what I have 20x10 but the shop will have to do a little trimming in the wheel well....as for tires I would recommend the 35x12.5 procomp xtreme M/T's they are very aggressive looking and their tire wear life is pretty long
SOLD2008 Titan 4x4 SE, 6" procomp stage 2 lift (coil-overs and MX6 ajustable shocks), PRG Drive Shaft Spacer, 35" Procomp xtreme M/T tires, 20x10 Black Rockstars, volant cool air intake, JBA Pipes to a Dynomax Bullet Dumped w/ resonated tip, headlight mod, 2 12" Kenwood subs in tech12volt box, HID 8000k lights HI/LOW, blacked out.
T-Dog23 is offline
post #5 of 9 (permalink) Old 03-11-2010, 06:59 PM Thread Starter
well i figured the trimming is gonna happen either way i look at it and i was gonna go with the trail grapplers the procomp tires are getting to expensive i figured my first set would be m/t's then go with the a/t's next
post #6 of 9 (permalink) Old 03-11-2010, 11:02 PM
NorCal 4x4's Avatar
Definitely will rub with the 10" width rims at the pinch weld. TC says factory BS is o.k. for a 35, so if you found a 9" rim with 5.5" backspacing it should clear the knuckle, and probably not rub at the pinch weld. But if you add UCA later and get the RC ones, you'd be better off getting 5" backspacing on the rims. The 10s will stick out too much unless, you get the 5.5" backspacing, or you get coilovers for additional lift, like a stage 2 kits come with, or the higher quality aftermarket coilovers like PRG offers.
post #7 of 9 (permalink) Old 03-12-2010, 04:03 AM Thread Starter
so it would be better to just go with the 20x9 35-12.50and hope the rims i'm getting have that backspacing would a 5.75 bs work
post #8 of 9 (permalink) Old 03-12-2010, 10:39 AM
NorCal 4x4's Avatar
Probably not ... RC says factory BS, (which is 5.5"), so you might end up with the tread blocks at the shoulder rubbing the RC steering knuckle. 5.5" or smaller BS should work. Hopefully, if you already ordered them, they were being conservative.
post #9 of 9 (permalink) Old 03-14-2010, 06:53 PM Thread Starter
no haven't ordered them yet just need my tax return then its going into play
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
4-6inch lift kit with front shocks? Colten K Titan Suspension 7 02-27-2010 11:26 AM
Trade my 26" rims & tires for your lift kit and tires MIKE858 Buy/Sell 1 02-16-2010 12:10 AM
WTB: 6inch lift Sprocket1 Buy/Sell 0 01-17-2009 08:31 AM
6inch lift sxfracer Titan General Discussion 16 11-08-2006 08:32 PM
You may post new threads
You may post replies
