Another "what size can I fit" thread. - Nissan Titan Forum
Old 08-04-2010, 11:20 AM   #1 (permalink)
iTrader Score: 0 reviews
I've got an '05 2wd with a 2.5" leveling kit. I'm currently running 17'' offroad OEM wheels with OEM Bridgestone Duelers in a 245/70/17. What is the largest tire I can run, specifically a Terra Grappler, that I can run with no rubbing? What is the largest tire I can run if I were to do the pinch weld mod?
Thank you,
David
--David
2005 Deep Water Kingcab 4x2 XE
Volant CAI
NCD 2.5" leveling kit
Viper alarm
Bed-lined 17" Titan off-road rims wrapped in Nitto Terra Grapplers in a 285-70/17.
Bed-lined rear bumper and badge.
Bed-lined cowl cover.
More to come...
wguy00 is offline   Reply With Quote
Advertisement
Old 08-04-2010, 09:42 PM   #2 (permalink)
NorCal 4x4's Avatar
iTrader Score: 4 reviews
Re: Another "what size can I fit" thread.
Thank you,
David
You can run the 33.2"x11.8 LT295/70R17 D without pinch weld trimming or mudguard removal, and maybe the 34"x12" LT305/70R17 E, (mine needed the pinch weld mod, because my rims stick out 1.4" more than the OR rims). The 33.86"x11.3" LT285/75R18 E would actually be a better match than the 305's for a 7.5" width OEM 17" rim. The speed rating on the 285/75's isn't as good as the other two though.
With a leveling kit, I'd probably get the 295s though since they are tall enough for that much lift, wider and a better speed rating than the 285/75's, and 7 lbs. a piece lighter than the 305s. They are also probably a little cushier since they have a D load rating instead of the 305's and 285's E load rating. They are also a better match for stock gear ratios, although aftermarket gears are available. If you have the 2.94 gears, the 295's would definitely be the better choice if you're keeping stock gears.
The Following User Says Thank You to NorCal 4x4 For This Useful Post:
wguy00 (08-05-2010)
Old 08-05-2010, 09:16 AM   #3 (permalink)
NorCal 4x4, that was awesome. Thank you for all the information!
--David
Volant CAI
Viper alarm
More to come...
Old 08-05-2010, 09:28 AM   #4 (permalink)
TITANBOY's Avatar
iTrader Score: 2 reviews
35's with the pwm
  • '05 Titan SE CC 2WD
    5100's(middlenotch)
    CST Spindles
    2.5 leveling kit
    35X12.5X18 BFG KM2's
    Debadged
    2 degree timing advance
    Air Box Mod
    Mesh Grille Mod
    Headlight Mod
    Homemade Traction Bars
    Homemade Tow Hooks
TITANBOY is offline   Reply With Quote
Advertisement
Putting on a PRG 2.5"/1" Mini Lift Kit; Which tires will fit on a stock 18" wheel? TennesseeTitan215 Titan General Discussion 3 10-08-2009 03:56 PM
The official TT "Will it fit?" thread... PSNissanFleetMgr Titan Wheels, Tires & Brakes 2 04-09-2008 03:17 PM
Yes they FIT, 2 12"s subs... "PORTED"!!! K-MU Titan Visual & Audio Discussion 16 03-22-2006 06:21 AM
Could 17x10" -21mm with 35" BFG MTs and Rancho 4" fit? K-MU Titan Wheels, Tires & Brakes 7 02-24-2006 03:51 PM
Minnesota Titan Owners - Check out "Minnesota Titans" thread in "Midwest" region. Half Shovel Titan General Discussion 4 03-06-2005 07:00 PM
SEO by vBSEO 3.3.2
