wheel and tire fitment question - Nissan Titan Forum
Old 09-17-2010, 09:57 AM   #1 (permalink)
iTrader Score: 0 reviews
I know there are a lot of these questions, becuase I have been searching. With all the different combos possible, I have not found a answer that I am comfortable with yet. I have a 09, CC, 2wd, Rough Country 3" level/lift kit, wheels I am going to put on are 18x10 with 0-0ffset (5" BS). I really want to run 325/60/18, but im not sure if it will contact the UCA or any frame/ suspension parts. I know I will need to massage the body a little. Anyone have a setup close to mine? Any input on what is needed to make these tires fit would be great.
Thanks
jkgts1 is offline   Reply With Quote
Advertisement
Old 09-17-2010, 10:34 AM   #2 (permalink)
NorCal 4x4's Avatar
iTrader Score: 4 reviews
Re: wheel and tire fitment question
Thanks
If the are 18x10's they are really 11" wide, and so with a 0mm offset, their backspacing is 5.5", so a 325 could very well rub on the RC UCA.
Wheel manufactures don't count the lips in the width, so their advertised widths are about 1" wider. A 18x9 rim with 0mm offset has 5" of backspacing, becaused measured it is 10" wide.
A 325/60R18 on 18x10 w/0mm will also rub at the pinch weld about the same as a 18x9 with -12mm offset ... 4.5" backspacing, because both will stick out the same.
You will need the pinch weld mod if leveled. See the link in my sig.
Old 09-17-2010, 05:27 PM   #3 (permalink)
Cool thanks for the help. My mistake the wheels are 18x9, 0- offset, been a while since I looked at them.
Advertisement
2008 Titan Wheel & Tire Fitment Question bosssho Titan Wheels, Tires & Brakes 17 01-21-2011 03:57 PM
Wheel/Tire Fitment Question willrw03 Titan Wheels, Tires & Brakes 4 01-23-2010 11:50 AM
another question about wheel/tire fitment Jiro Titan Wheels, Tires & Brakes 3 02-09-2009 02:50 PM
wheel and tire fitment ? troutman Titan Wheels, Tires & Brakes 1 05-03-2007 02:08 AM
wheel and tire fitment troutman Titan Wheels, Tires & Brakes 3 04-05-2007 10:13 AM
SEO by vBSEO 3.3.2
