Brake/ABS problem - Nissan Titan Forum
post #1 of 4 (permalink) Old 01-22-2011, 08:46 AM Thread Starter
iTrader Score: 0 reviews
Brake/ABS problem
Have an 04 Titan 4X4 with 45K on the clock that is having wierd brake issues. Has anyone had an issue with the brakes intermitantly becoming very spongy, ABS, SLIP, VDC and Brake warning lights all light up and the ABS pump sounds like it's being actuated (producing a wierd creaking noise that you can feel in the peddal). I can turn the ignition off let it set for a little while and start it up and everything is back to normal...till the next time it does it.....no rime or reason to the time or place it will do it next. Brake fluid looks good and connections on the booster and ABS pump are tight with no corrosion.
Is there a recal or any TSBs on issues like this? Any help appreciated.
kirkhurst is offline
Advertisement
post #2 of 4 (permalink) Old 01-22-2011, 09:09 AM
iTrader Score: 4 reviews
Re: Brake/ABS problem
I have an 04 4x4 also and have had this happen once in 100K:
Sudden Total Brake Failure
bestatchess is offline
post #3 of 4 (permalink) Old 01-22-2011, 12:48 PM Thread Starter
Bestatchess,
Thanks for the info...wow, did not realize so many were having the same issue. I'm the original owner and don't drive the truck much; primarily for pulling the boat, guess I'm really lucky has'nt happened while towing....Off to the stealership I go with TSB in hand......man, this should be a recall; someones gonna get hurt!
post #4 of 4 (permalink) Old 01-22-2011, 04:50 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
No kidding. Given the bas press that Toyota got you would expect Nissan to be all over this. Fortunately, this seems to occur very rarely.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Anybody have this brake problem yet?? madahajimoto Titan Problems & Dealer Service 1 07-17-2009 12:03 PM
Brake problem FELIPON619 Titan Wheels, Tires & Brakes 0 04-28-2009 12:26 AM
brake problem? jay817 Titan Wheels, Tires & Brakes 5 12-30-2005 08:17 AM
'05 brake problem CMC#64 Titan Wheels, Tires & Brakes 6 09-09-2005 08:25 AM
05 Brake Problem Calhoun687 Titan Problems & Dealer Service 8 05-27-2005 06:11 AM
You may post new threads
You may post replies
