07-15-2004, 02:03 PM
#4
Yup, they're reusable. They're also fairly common, so your tire guys should know how to deal with them.
Pull the valve out of the stem to deflate the tire first. Remove the nut on the valve stem - you can push the valve stem into the tire at this point. The manual tells you to do that to avoid sensor damage while breaking the bead while removing the tire. Depending on the type of equipment used to remove the tire, it may not be necessary, but it can't hurt.
