Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Wheels, Tires & Brakes
User Name
Password
Balancing Weights? - being discussed at Nissan Titan Forums in the Titan Wheels, Tires & Brakes section.
Old 07-15-2004, 08:26 AM   #1
ttammunek04
ttammunek04's Avatar
Balancing Weights?
I had a flat yesterday morning, and was going to take my wifes' Xterra for new tires so I threw they flat into the back to get patched. To make a long story short, After i got home I noticed 4 or more marks on the inner side of my rim. Probably about 2" x 1". Are these stick on wheel weights or what? Will it hurt if these have been removed and wheel weights have been added to the edge or bead of the tire? If I had a camera I would post some pics but no camera. Any help would be appreciated. Oh by the way I have the 18" SE 5 or 6 spoke rims if anyone wanted to know.
2004 Nissan Titan SE KC
2006 Polaris Sportsman 500 EFI
Mods:
K&N Drop in Air Filter
Flowmaster Delta Flow 40 series exhaust
Custom Built Diamond Plate Drop-in Tool Box
AVS Bug turd deflector
P265/70/18 Bridgestone Dueler Revos
ttammunek04 is offline   Reply With Quote
Old 07-16-2004, 04:55 PM   #2
Big Platinum
Big Platinum's Avatar
A lot of places use the stick on weights depending on what type of rim, nothing to worry about. Rim/tires are computer balanced, the computer tells the tech where to put the weights, then after intalling they recheck the balance to make sure.
CC LE Smoke
JBA Cat Back Exhaust
K&N CAI
10" Fosgate He2
-Emerson
Big Platinum is offline   Reply With Quote
Old 07-16-2004, 08:35 PM   #3
BigRedTitan
BigRedTitan's Avatar
The SE wheels have stick-on weights toward the outside of the wheel (behind the spokes) and clip-on weights on the inside of the wheel. The outside rim is not made to have the clip-on weights. If you remove the stick-on weights, you will cause your wheels to become unbalanced, making for a very bumpy ride.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin Street Pilot C530 GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
Old 07-17-2004, 10:17 AM   #4
mikeody2003
mikeody2003's Avatar
Not to worry, like Big Platinium says they always check them to make sure. I have 22 wheels and I looked at one of them and it has like 50 of those 1/4lb weights. They are stuck at the back and on the lip only way to see them is if you really look hard and inderneath the truck to look on the other side. I was scared at 1st when I saw that many and started to ? why it need so many but with the tire and wheel that i have it need to be computer balance right; hate to waste more gas and steering problems later on down the road.
mikeody2003 is offline   Reply With Quote
Old 07-19-2004, 11:10 AM   #5
ttammunek04
Think that I figured out what the marks were. I checked and my other rim didn't have stick on wheel weights so I am assuming that it was some grease or something on the machine that was used to hold the rim while taking off the tire. I wouldn't think that it would take 5 or 6 weights to balance a tire. Went to Birmingham (About 50 or 60 miles from the house.)Saturday and everything rode well. So, I guess I was just being a worry wart.
Old 07-19-2004, 03:45 PM   #6
Austin
Austin's Avatar
Low quality tires and/or low quality wheels have less uniform construction and will generally take more weight to balance.
The average 22" wheel is made more with bling in mind than anything else, and, when comparing wheels of identical materials/fabrication method, they tend to be much lower quality than a good 16/17/18" wheel.
MY04 SE King Cab 4X4 SOLD!
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
