Im about to slap a 6" Rough Country lift on my titan. I bought some 35" super swampers (35x12.50) on a 15x10 rim. My question is. Will I be able to roll around with these rims or am i gonna be constantly rubbing. If you have pics that would really help to get the look down.
__________________ 06 TITAN WITH 6" Rough Country
36x13.50 SUPER SWAMPER IROKs
17x9 Level 8 Strike 6 WHEELS
Pretty much need a 17" on an older Titan, and an 18 on the '08+ as the minimum. There have been a few people that have fit 16's with grinding on the '04-'07. Look for an 8.5" rim width as maximum for less rubbing potential, in a 4.75" to 5" backspacing, at least with their old UCA's.
Yeah, the other posters are right... You will never fit 15 inch rims over the brakes on our trucks. You might as well start looking for a jeep guy to sell those wheels and tires to.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33x12.50r17LT Hercules Trail Digger tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, Hawk LTS brake pads, MOOG lower ball joints, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
Also as Norcal pointed out, backspacing and TIRE width are the key points... I'm running 35x13 on OEM Rims with 1.25" wheel adapters and had to Sawzall the snot out of my fender pinchwelds where if I wasn't too lazy to remove the adpters they would've fit just fine. 8"-9" rims fit great, a few people have fit 10" rims but finding the correct backspacing on 10" rims can take alot of work.
Fox Delta ran 37x13.5 Toyo M/T's on the 17" off road rims, with a ProComp lift plus coilovers, but wheel spacers would cause too much rubbing at the pinch weld. I think the RC kit is higher than the PC stage 1, (no coilovers, just a big strut spacer), so maybe with a skinny 37" on the stock 17's w/o the wheel spacers. You would have a better chance with one like the BFG A/T KO 37x12.5R17D which is 36.3" diameter, and about 12.8" wide on a 10", so would pull in to about 11.8 to 12" on a 7.5" with rim. Probably need the pinch weld mod and it might rub the RC UCA's.
Dropped off the titan today for the 6" RC lift install... got a hold of some 37" CL Junkers and told the shop to throw them on in the mean time until im able to get some new rims and 35's... I told the shop to mount the 37x12.50 on my stock 17x7.5 wheels... They said they would try... Will this work??? I mean will a 37x12.50 actually grab on to a 17x7.5 wheel???? Truck will be ready on Wed I'll have pics up
As mentioned above, it's been done. I probably wouldn't do it, but a lot of people run 325s, which tend to be wider than the 12.5" tires on the stock 18x8" rims. Never heard of anyone losing a bead, and the guy with the 37x13.5R17 Toyo M/T's on the off road rims aired his down to 12 psi or so when we were on a snow run. We weren't ripping or anything, just were getting too much tire spin on the hard pack and ice on the forest road.
You will likely need to trim at the pinch weld if you aren't running coilovers. Hopefully they are on the small side for 37's, like the BFG KO's I mentioned ... I guess if they are junkers, most of the tread will be gone which will make their diameter smaller, closer to 36" even if they were true 37's.
My 2 Wheel Drive Titan on a Rough Country 6 Inch Lift with 37x12.50 BFG Tires on 17x7.5 Stock wheels. All fit in with no cutting or trimming of the plastics. Didn't rub once driving around and making turns.
The Following User Says Thank You to AZbum For This Useful Post:
