275/60R20 & chains - Nissan Titan Forum
post #1 of 9 (permalink) Old 12-17-2011, 01:54 AM Thread Starter
iTrader Score: 0 reviews
275/60R20 & chains
Ok so I've done some searching and read some threads including "Tire Chains 101". Had a look at tirechains.com and their info. But there's something I don't quite get.
In the owners manual for the 2010 it specifically tells us that we can't run chains with the 20" wheel & 275/60R20 tires. It advises that for chains you should have 18' wheels & 265/70R18. So I checked and there's less than a half inch difference in both Overall Diameter & Section Width.
So how do 265/70R18 magically make it OK to chain up?
Thanks,
D
don_chuwish is offline
Advertisement
post #2 of 9 (permalink) Old 12-17-2011, 05:47 AM
timmy_g83's Avatar
Re: 275/60R20 & chains
What do you need chains for?
timmy_g83 is offline
post #3 of 9 (permalink) Old 12-17-2011, 08:46 AM
AZPRO4X's Avatar
iTrader Score: 8 reviews
When I bought my truck I had to sign a supplemental paper that said if I used chains it would void my warranty & I have 18's.. I just can't remember if it was a California thing or Nissan thing.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
2016 XD Pro4X Gasser
AZPRO4X is offline
post #4 of 9 (permalink) Old 12-17-2011, 10:42 PM Thread Starter
1) required to carry over some OR passes when conditions are bad enough
2) to actually be able to drive when conditions are that bad
A separate set of studded snows is an option, but a very expensive one.
I just don't get why the manual would say it's OK for 18" wheels but not 20" wheels when the overall outside diameter of the tire barely changes.
- D
post #5 of 9 (permalink) Old 12-18-2011, 04:11 AM
timmy_g83's Avatar
Just giving you sh#t. I was in WA state and know that the passes can get crappy out that way. I'd just find a set of traction tires and a different set of rims for the winter. Save you some hassle and make it easy to swap out.
post #6 of 9 (permalink) Old 12-18-2011, 04:41 AM
NBhunter80's Avatar
Most people have seen issues with the chains rubbing on the spindle, not on the wheel well. That is why the rim diameter makes a difference (obviously running too large of a tire does as well). The 20" rim probably puts the spot where the chains mount closer to the spindle and that causes rubbing when the chains twist. So if you have to change rims anyway, I would get a set of studded MTs if you plan on doing serious winter offroad driving. I got my 33" x12.50" trail diggers for $230 per tire, and they have factory stud-mounting locations. I believe the firestone destination MTs also are made for studs.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #7 of 9 (permalink) Old 12-18-2011, 10:25 AM Thread Starter
Thanks guys, I'll have to pass on the suggestion. I've seen some stock 18s for sale that would be great for a 2nd set of snows, but all said it'd still be well over $1K.
My folks got the truck after totaling their Sierra on a black ice slide & roll. So budget is tight after an unexpected truck purchase & right at Christmas. But given the lesson the black ice slide should teach...
post #8 of 9 (permalink) Old 12-18-2011, 08:46 PM
HRTKD's Avatar
Garage
iTrader Score: 2 reviews
In my "Tire Chains 101" I postulated that the proximity of the spindle may be why Nissan says chains on the front are a no-no - even with 17" rims. One of these days I'm going to try my chains on the front just to see what happens. But I need some snow first.
When I grew up in Wyoming we chained up all four tires. But this is back when there was no such thing as electronic transfer cases or trucks with small wheel wells.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned, CSF radiator, e-fans, JBA LT headers»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
2017 Ford F-350 CCLB 6.7l Lariat - The Towing Beast
Jim aka Bionic Whore™
HRTKD is offline
post #9 of 9 (permalink) Old 12-19-2011, 12:02 PM
smon's Avatar
Here is my recent discovery with chains. I couldn't bring myself to buy a set of those class "S" chains for my titan. So I went with heavy duty twisted link from tirechains.com on my 2011 pro4x. I have the stock 275/70r18's and they fit fine with a dry test. I am running heavy duty vbar on the rear with quite a bit of clearance. Didn't get the chance to run them hunting this year, but most likely will next week up in the mountains.
My tires are almost the exact same dimensions as those 20's, the difference will be how far the chains come down the sidewall. My chains hit at the widest part of the sidewall and I have a little less than 1/2" inch of clearance to the spindle. I would imagine that 20" tires would actually have a narrower sidewall (random tire choice showed .1" less-maybe more with a stiffer sidewall tire), giving a little extra clearance. Someone else on here used those class "s" chains and broke both very quickly off road.
If you go with the heavy duty ones, ask them how wide the chains are compared to the ones that fit 275/70r18's. If they are more narrow, that will also give more clearance as the spindle gets closer to the tire the further down it goes (closer to wheel). Also make sure and get ones with cams to help tighten the chains towards the outside of the tire.
Worst case, you can go class "s" up front and heavy duty out back.
smon is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
New Falken Ziex STZ-04 P275/60R20 TSP4 Buy/Sell 9 10-29-2010 01:57 PM
Tire chains ablexus Titan General Discussion 7 12-22-2008 03:40 PM
Chains...help! pharcyde_titan Titan Wheels, Tires & Brakes 4 12-21-2008 06:35 AM
Quesion about WD chains.. HudsonValleyTitan Titan Towing & Hauling 4 05-22-2008 05:11 PM
305/60R20 Toyo A/T Will it fit? GrayB83 Titan Wheels, Tires & Brakes 0 11-27-2007 07:03 PM
You may post new threads
You may post replies
