TCE to offer new Big Brake kit! - Nissan Titan Forum
Old 04-05-2012, 03:59 PM   #1 (permalink)
iTrader Score: 0 reviews
Been stewing on this for some time now and finalized some test fit items today....your Thursday afternoon new product!
TCE Performance Products is adding an all new Wilwood W6A caliper kit to our popular line of Big Brake Kits.
This new kit is a true caliper only kit built specifically for the 13.75 or 350mm disc. You can now replace your stock two pot floater with a lighter, more responsive, more thermal efficient six piston caliper!
The W6A kits have been offered and fit with great success on our TCE Charger/Challenger platforms from the humble beginings of the Magnum. This set up has been a winner as it's both functional and appearance enhancing. Many folks have upgraded their older and smaller rotors but are still stuck with the boat anchor, sliding, two piston calipers...well no longer.
Some test fit and such from earlier today:
This caliper kit is currently being listed for $1495 complete. However I'm looking for some beta testers for feedback and input...if anyone is interested please let me know.
Right now TCE is also considering a wider and larger rotor kit also pending reception of this kit. Also being talked about is a matching rear caliper kit for those who would prefer matching sets.
TCE
Your One Stop for Wilwood Brakes
Todd TCE is offline   Reply With Quote
The Following 3 Users Say Thank You to Todd TCE For This Useful Post:
gweasel77 (04-06-2012), OFELIPE (04-13-2012), Stilltime (04-06-2012)
Advertisement
Old 04-05-2012, 05:48 PM   #2 (permalink)
iTrader Score: 2 reviews
Send a message via MSN to nismojunky
Re: TCE to offer new Big Brake kit!
id be interested in testing few questions what size of rim do you need to run this set up, what year of truck will it fit the pre 08's have smaller rotors
2006 Titan CC Offroad
Factory Options - Granite, E-locker, Big Tow, RF, Utili-Track
Performance - JBA Cat back, S&B CAI , Rear Axle Vent, TrueTrac, DIY Ground Kit, UpRev, Power Stop Brake Kit, 2* , WOT Removed, TB Bypass, Vibrant UQ res, Burnout Modd, OBX LT Headers, Cajin Catted 4x4 B-pipes, CST alu rad
Suspension - Driveshaft Spacer, PRG Cam Bolts, PRG SBEL's, PRG Shackles, C-30 Leafs, PRG OFFROAD Traction Bars, Radflows on 4", PRG UCA's, 1" Blocks Rear, Air lift Airbags
Exterior - 4X Hella 500 Black Magic Driving lights, 6k HI/Low/Fogs, Backup lights, Back Rack, 35/12.5/R17 Nitto Trail Grapplers
nismojunky is offline   Reply With Quote
Old 04-05-2012, 06:05 PM   #3 (permalink)
nyc2005armada's Avatar
iTrader Score: 1 reviews
I'm in for testing, I am running a 2005 Armada, and I am running a 22' rim.
Performance mods: DT Long tube headers, hi-flow Magnaflow cats, Injen intake, 07 style exhaust pipes, 22 inch magnaflow muffler (12588) Cross drilled/slotted front rotors, Bilstein 5100 front shocks.
Exterior Mods: Stock LE rims, painted Nissan Galaxy black with Nismo center stickers, 5000k headlights and 6000k fogs
Interior mods: All red led instrument cluster, 12 in JL sub, 250W mono sub.
nyc2005armada is offline   Reply With Quote
Old 04-05-2012, 06:40 PM   #4 (permalink)
Hey TCE!
I'm a RX8 owner and I have personally seen good quality out of a RX8 equipped with your upgrade kit. This kit will replace pre-2008 smaller brake rotors with a larger set? If so get ready for lots of great interest..me being one of them!
//CST Lift//18" KD Series Misfit Rims//Nitto TeraGrapler Tires//PRG Sway Bar End Links//PRG Upper Control Arms//Electric Exhaust Cutout//
gregs is offline   Reply With Quote
Old 04-05-2012, 07:14 PM   #5 (permalink)
T-Dog23's Avatar
I would be interested!!! I need a new front setup!!!
FOR SALE2008 Titan 4x4 SE, 6" procomp stage 2 lift (coil-overs and MX6 ajustable shocks), PRG Drive Shaft Spacer, 35" Procomp xtreme M/T tires, 20x10 Black Rockstars, volant cool air intake, JBA Pipes to a Dynomax Bullet Dumped w/ resonated tip, headlight mod, 2 12" Kenwood subs in tech12volt box, HID 8000k lights HI/LOW, blacked out.
T-Dog23 is offline   Reply With Quote
Old 04-06-2012, 06:46 AM   #6 (permalink)
Stilltime's Avatar
iTrader Score: 3 reviews
I am definitely interested, for use on my 2010 with either 18" or 20" wheels.
Chris C.
2010 Titan SE
MDE250 + MSE300 In.The.Works
_____________________________________
2010 Titan 4X4 SE
Modular True Duals/Cajun B-pipes/Airaid/BDGT
Stillen FSB/Hellwig RSB
CNC Sway Bar Mounts + Poly Bushings
PRG Endlinks
Bilstein 5100/5125's
Nitto Trail Grapplers 295/70/18
Where Are You From? TitanTalk MemberMap
TitanTalk MemberMap - Sign Up Here!
Stilltime is offline   Reply With Quote
Old 04-06-2012, 06:51 AM   #7 (permalink)
Stilltime's Avatar
Looks like I can't send you a PM, get ahold of me if you can I am definitely eager to see this kit and how it performs under heavy braking and how well it handles fade.
Chris C.
2010 Titan SE
2010 Titan 4X4 SE
PRG Endlinks
Old 04-06-2012, 07:35 AM   #8 (permalink)
Please check back to this post throughout the day as I will add to it.
What exactly is this now? The TCE Caliper Kit is a caliper only package designed to fit the later Titan 13.75" rotor. It allows you to replace the twin pot slider with the functionality of the six pot.
What rotors are these again? This is the later model oe rotor (or equivalent) only. It will NOT fit the smaller 12.6 rotor in any way.
What year does it fit?
It's being shown above on my own 2004 (107k) and will fit all 04-06 vehicles.
What about later models?
I believe we have cross fit all the way up through the current truck. *This is where we'll be looking for some additional help. The 13.75 came into the line in 2007 and others have been supplying this rotor with a new slider 'cage' or bracket for updating the earlier truck. Deducing from that and personal cross checking of the parts (the width is the same, the offset the same etc) we are making a certain assumption that this same package will roll right on through the latest years.
What's the register ring thing about?
A difference (only one found really) between the older rotor and newer one is the size of the center bore or hole. The newer rotor is larger and will not be hub centric. Leaving them to center on the stud holes is discouraged. I do not know of any castings that have the smaller hole abut the larger diameter. TCE will be offering optional centering rings also.
Why aren't they included?
Because some folks with later vehicles would not require them.
Can I get the rotors drilled? Or dimpled? Or do you just do slotted?
Let me reiterate; the kit does not come with rotors. You must supply your own 13.75" ebay or otherwise sourced rotors.
What's that about spindle clearance and grinding....? Due to the length of the ARP stud for the caliper mount it breaks out just into the pocket area of the bracket and contacts the iron. Had this rotor been a full 14.25"...well that would not be the case as the stud would not be so deep into the bracket! But it is and we have to deal with it. Far easier for you with a Makita than the need to try and assemble it and re mill it here post production. Took about 2min and won't compromise the integrity.
Does this fit the 4WD model?
From what I see the answer is yes. The same rotor and same calipers are use stock.
What about ABS? Fully functional, un effected.
Can I have another color other than black or red? Yes and no. Right now they are standard from Wilwood in these finishes. They offer other colors but time will be a serious issue.
Can't I just have them painted or PC'd myselft? While I can't stop you...I'd highly discourage it. Taking them apart and having them fully stripped before paint or PC is more of a risk than a reward.
How hard is this to install? I mean really. If you can service the stock brakes you can do this. Bolt up is simple other than the clearance mentioned above. You will need a flare wrench for the ss hoses. And fluid.
Oh, so how much are the hoses? They're included.
Should I use DOT5.1 race fluid in these then? Absolutely not. Unless you can afford it. There's no need for more than conventional DOT3 or DOT4 fluid. If you're not boiling the fluid you use now you don't need higher boiling point fluid...Brake fluid does not improve braking.
So the six piston will be three times as good as what we have right? Not exactly. The multiple piston caliper applies pressure from both sides and more even pressure on the pad itself. The slight reduction in piston area will firm up the pedal response and feel. It will also help the overall bias of the truck a bit by countering some of the added nose dive one might experience with the 2 pot set up on this rotor.
Will it shorten my stopping by 20ft? I doubt you'll see that. A bit perhaps but like most trucks you'll be "tire limited" unless you run some Hoosier slicks or something. The added response and feel will be time gained however and modulation is a huge increase.
So where do I get pads and how hard are they to change?
Any Wilwood dealer has a variety of pads for this caliper. They maybe available from others such as Hawk too. Removal is by way of two retainer pins. You'll hardly get you hands dirty.
How do I know it will work, like the looks but man...$1500 bucks~!
Nope it's not cheap. Calipers alone run about $500+ each. Add pads, hoses and the milled radial mount bracket....plus advertising costs, packaging, cc fees....yes; TCE is here as a business but I feel the price is fair and justified.
Has it really been proven tho, come on...never heard of you.
I probably don't know you either. But feel free to surf the net for the company with regard to Magnum/Charger, Lightning, WRX and others. If that's not enough keep in mind it's the same caliper found on a lot of Corvette kits now and is the factory supplied caliper of choice on all new Shelby GT500s. With many customers beating the crap out of it on the track- I'll put my name on it's success any day.
What's up with the talk of a 14" kit?
In the thought process. I'm just not clear on the need for a larger kit to that spec yet. Both market and function. This rotor is pretty nice really for the needs of most folks. Adding the cost of 2pc hats and rotors will up the fee by another $700. How many people are buying $2200 front kits? But if we do decide to offer it the caliper will carry over for a retro fit- thinking ahead here for you.
So we need to run wheel spacers?
Right now on my 04 wheel yes. You will need a 6mm spacer. (.25 or so actually) With the wheel spacer in place (stock wheels-Titan) you will definitely need longer studs. A quick check shows about 5mm of thread engagement with the stock wheel/nuts and that nowhere near adequate. Here's the reason for the spacer.
I ditched those long ago and run 22s so I'm golden! Well, maybe, maybe not. I'll put up wheel fit info shortly and see. It's not the diameter, it's the spoke clearance. Deep dish or wide lip wheels generally don't go well with big brakes.
But can I get them cross drilled? Let's start over...
PRICING OPTIONS FOR INITIAL SALES:
As we intend to run the revises brackets in the next couple of weeks I've decided to put up the kits as a Group Buy of sorts. *If this is a problem in this forum please advise as to where to move it.
1. Early Truck (04-07) buyer: Complete kit, red or black, shipped (US), $1250. $500 non refundable deposit secures the buy, balance due when shipped. T
2. Later Truck (08+) buyer: Complete kit, red or black, shipped (US), $1250 $500 non refundable deposit secures the buy, balance due when shipped.
3. All others; $1375 shipped. $200 non refundalbe deposit, balance due upon completion.
The goal here is to both offer YOU the customer a chance as some significant savings as well as allow me to truly gauge the interest level and production qty of parts to move forward. Please note that it will not get any better than this in the future. These kits will carry a retail price of $1489 and I have removed the sale of wheel spacers. TCE will offer the rotor register rings only at this time for an additional cost of $35. ($25 for above sales, free with #1) The pricing above will be open thru April 21st only. Options #1 and #2 are on a first come basis and limited to one buyer each. (Chris, here's your chance to save) Brackets will be run the week following and shipping the week of May 1st. Are you ready??
**Additional info later with regard to wheel fit and other items.
*Seem to be having PM issues. For now feel free to email directly at toddanchris1@cox.net
TCE
gweasel77 (04-06-2012), honda250xtitan (04-06-2012), Stilltime (04-06-2012)
Old 04-06-2012, 02:41 PM   #9 (permalink)
T-Dog23's Avatar
I'd be able to see how it works on a lifted titan with bigger tires!
Old 04-06-2012, 03:19 PM   #10 (permalink)
gweasel77's Avatar
iTrader Score: 6 reviews
WOW!!! That's awesome that you guys have stepped up & are now offering a bolt on Wilwood Caliper that utilizes the '08+ OEM rotor size!
I would love to have a set of these on my T!!! Their a little rich for my blood at the moment, but its nice to know that we have an option available to us!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nismo LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page:http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods: CAJUN PIPES!!!!
gweasel77 is offline   Reply With Quote
Old 04-06-2012, 03:28 PM   #11 (permalink)
stryker125's Avatar
iTrader Score: 7 reviews
Send a message via ICQ to stryker125
That looks great! Sounds like a must have for guys running 35x12.5 and bigger!
-2008 PRO4x-
RC 6"
RC Traction Bars
35x12.5 Federal MT w/ 2" wheel adapters
PRG DS spacer
SS Brake Lines
Borla ProXS
4" Airaid MXP CAI
BDPP
5k/3k 35w HID lows/fogs
Waiting for Insallation:GO Rhino Dominator 2 steps,
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety."- Benjamin Franklin
stryker125 is offline   Reply With Quote
Old 04-06-2012, 03:37 PM   #12 (permalink)
Been buys (again) with other things here and have not had time to add to that post...I'm trying for tomorrow tho!
TCE
Old 04-06-2012, 04:12 PM   #13 (permalink)
So it won't fit my 17" stock offroad rims???
Old 04-06-2012, 04:19 PM   #14 (permalink)
Stilltime's Avatar
Not from the sounds of it unfortunately. Looks like its designed for the late model 13.77" brakes, 18" wheels minimum required.
Chris C.
2010 Titan SE
2010 Titan 4X4 SE
PRG Endlinks
Old 04-06-2012, 05:00 PM   #15 (permalink)
honda250xtitan's Avatar
I'd love to run wilwoods on my Titan.
2011 White CC pro4x
Flowmaster Y
Banks Muffler
Airaid MXP 4" Intake
PRG UCA's
Extended travel Sway-Away 2.5 coilovers
PRG Camber Bolts
Homemade Traction Bars
Fuel Boost 18x9
Nitto Terra Grapplers 295/70 18
Front BORA 1.25 Wheel Adapters/ Pinch Weld Mod
6K HID's
10" Sub/Kenwood Amp
Gone Forever: 06 KingCab 4x4
6" ProComp, Bilsteins 5100's, 08 4x4 coils, PRG UCA's, Banks CatBack, Nismo Cai, Superchips Cortex, Custom Bumper, 35's on 18's
honda250xtitan is offline   Reply With Quote
The Following User Says Thank You to honda250xtitan For This Useful Post:
Advertisement
stock headlights and 3rd brake light from 07 titan make offer BAMTNM Buy/Sell 0 10-28-2009 07:49 PM
What would you offer? Dirt Devil Titan General Discussion 10 07-27-2008 12:01 AM
How is this offer? memsu Titan General Discussion 16 02-28-2008 03:28 AM
Last offer cst silver Buy/Sell 0 12-10-2007 03:22 PM
Do You Think Nissan Offer Will Offer '05 Incentives? BDTITAN Titan General Discussion 5 11-19-2004 10:56 AM
SEO by vBSEO 3.3.2
