Lug Nut Torque Specs.... - Nissan Titan Forum
post #1 of 19 (permalink) Old 06-28-2012, 01:36 PM Thread Starter
iTrader Score: 2 reviews
I'm going to go get my new tires mounted today after work at Discount Tire and noticed they put down 108 ft-lb for the torque specs. That seems high and I know in the manuel it says 98 ft-lb. My question is do most of you torque to the 98 ft-lb or do you think even that is a little much? Thanks.
2007 Majestic Blue CC LE
Apperance Mods (Interior/Exterior): Wade In-Channel Window Deflectors; Chrome Billet Grille; WeatherTech DigitalFit FloorLiner; etched glass TitanTalk and AEM window decals(thanks Mo-Titan); Leonard's Low-Pro Toolbox; PRG 2.5" Leveling Kit; 275/70/18 Hankook DynaPro ATM RF10s
Performance Mods: AEM Brute Force CAI; Banks Monster Exhaust
To Do List: Performance Tuner; Bilstien 5100s; Kenwood DNX headunit; Hydro-Dipped Interior Pieces....
NCTitan4 is offline
Advertisement
post #2 of 19 (permalink) Old 06-28-2012, 01:44 PM
Stock '06's Avatar
iTrader Score: 4 reviews
I go to 93 ft. lbs myself
Sent from Titan Land
"UNDER CONSTRUCTION"
2006 KC XE Galaxy Black
INTERIOR LEDs/ EXACT SEAT COVERS Front and Rear/ Diamond Audio Subs and Amp/ Custom Bezel
EXTERIOR LED Tails, 3rd brake and Cargo and LP/ 5k Fogs and Lows/ Stubby Antenna / Hunter Bull Bar/ MB Stryker 17s / Bedlined BT Mirrors/ Armada Airdam/ LSAUTOLIGHTING.COM Engine Bay Kit/ Projector lighting
PERFORMANCE S&B Intake/ Cortex Tuner/ Tru-Cool Trans Cooler/ Grounding Kit/ Stillen Dual Exhaust/ PRT Catless B-Pipes/ 5100's on front and rear
Stock '06 is offline
The Following User Says Thank You to Stock '06 For This Useful Post:
NCTitan4 (06-28-2012)
post #3 of 19 (permalink) Old 06-28-2012, 01:49 PM Thread Starter
Re: Lug Nut Torque Specs....
Ok, thanks. Anyone else?
NCTitan4 is offline
post #4 of 19 (permalink) Old 06-28-2012, 01:52 PM
sudden urge's Avatar
90 ft lbs on mine.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is offline
The Following User Says Thank You to sudden urge For This Useful Post:
post #5 of 19 (permalink) Old 06-28-2012, 01:55 PM
Stilltime's Avatar
iTrader Score: 3 reviews
Could have sworn my manual said 104ft.lb. I'll have to check.
Chris C.
2010 Titan SE
MDE250 + MSE300 In.The.Works
_____________________________________
2010 Titan 4X4 SE
Modular True Duals/Cajun B-pipes/Airaid/BDGT
Stillen FSB/Hellwig RSB
CNC Sway Bar Mounts + Poly Bushings
PRG Endlinks
Bilstein 5100/5125's
Nitto Trail Grapplers 295/70/18
Where Are You From? TitanTalk MemberMap
TitanTalk MemberMap - Sign Up Here!
Stilltime is offline
post #6 of 19 (permalink) Old 06-28-2012, 01:57 PM Thread Starter
Chris C.
2010 Titan SE
Could've sworn mine said 98 ft-lb...lol
NCTitan4 is offline
post #7 of 19 (permalink) Old 06-28-2012, 02:18 PM Thread Starter
So somewhere around the 90-95 range
NCTitan4 is offline
post #8 of 19 (permalink) Old 06-28-2012, 02:52 PM
iTrader Score: 0 reviews
I do 90 ft/lbs on my aftermarket aluminums. Works great
An un-related side note: I actually had a wheel fuse to the front rotor last month. Never had that happen in my life. Blaster soaked for 12 hours and did the trick though.
LouG68 is offline
post #9 of 19 (permalink) Old 06-28-2012, 03:08 PM Thread Starter
Good to know
NCTitan4 is offline
post #10 of 19 (permalink) Old 06-28-2012, 03:56 PM
Send a message via MSN to nismojunky
usually do 105 my self
2006 Titan CC Offroad
Factory Options - Granite, E-locker, Big Tow, RF, Utili-Track
Performance - JBA Cat back, S&B CAI , Rear Axle Vent, TrueTrac, DIY Ground Kit, UpRev, Power Stop Brake Kit, 2* , WOT Removed, TB Bypass, Vibrant UQ res, Burnout Modd, OBX LT Headers, Cajin Catted 4x4 B-pipes, CST alu rad
Suspension - Driveshaft Spacer, PRG Cam Bolts, PRG SBEL's, PRG Shackles, C-30 Leafs, PRG OFFROAD Traction Bars, Radflows on 4", PRG UCA's, 1" Blocks Rear, Air lift Airbags
Exterior - 4X Hella 500 Black Magic Driving lights, 6k HI/Low/Fogs, Backup lights, Back Rack, 35/12.5/R17 Nitto Trail Grapplers
nismojunky is offline
post #11 of 19 (permalink) Old 06-28-2012, 10:30 PM
BushLeague's Avatar
I stop at 95 ft/lbs. never had one fall off and had to fix to many which were over torqued.
BushLeague is offline
post #12 of 19 (permalink) Old 06-28-2012, 11:12 PM
kdo2milger's Avatar
iTrader Score: 8 reviews
its 98 ft lbs
kdo2milger is offline
post #13 of 19 (permalink) Old 06-28-2012, 11:42 PM
CVTitan05's Avatar
iTrader Score: 5 reviews
Impact :P lol, idk how tight they get. Sometimes I'll use a 100 ft/lbs torque stick though. Honestly 10 ft/lbs on lugs arent going to make a difference.
2005 Titan KC XE 2wd. Dirt King Mid Travel SOLD
2008 Titan CC XE 2WD. 2" Leveling kit.
2005 Titan CC SE 4x4 10" Lift. Build Thread
CVTitan05 is offline
post #14 of 19 (permalink) Old 07-30-2013, 06:52 PM
spta97's Avatar
I think it is more important to get them all to the same tightness rather than exactly to 98 ft/lbs.
I bought torque sticks but never understood how they worked and therefore didn't trust them
2007 Armada LE - It's like a Titan with a trunk!
spta97 is offline
post #15 of 19 (permalink) Old 07-30-2013, 07:42 PM
JLG7820's Avatar
Garage
Discount tire does 105 on mine with my after market wheels and lugs. They said it is what their computer said
Sent from AutoGuide.com App
2006 silver KC 4x4.
RC 3inch Leveling Kit
Pro4x Springs
Bilsteins 4600 HDs
2*Timing advance
K&N 77 Series
Bully Dog Power Pup
3inch Cat back exhaust
18x9 MB Razors
305 65 18 falken Wild Peak
JLG7820 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Linear Mode Linear Mode
SAW torque specs???? Rhino404 Titan Parts & Accessories 13 05-31-2009 07:56 AM
Need Torque Specs JBrawn Titan Parts & Accessories 8 09-09-2008 08:22 PM
Torque specs on UCA????? supersport2002 Titan Suspension 6 02-29-2008 09:11 PM
torque specs ucas Taylor Titan General Discussion 3 12-30-2006 10:58 AM
You may post new threads
You may post replies
