Im getting ready to order my wheels and tires but im not sure what offset i need for my truck. Its a 2010 crew cab SE 4x4 titan. I have a 3" front leveling kit and a 1" rear block. I want to order 18x9 Fuel Hostage wheels and 295/70R18 Nitto Trail Grappler M/T tires. These are the offsets available -12mm, +1mm, +14mm, or +20mm offset. Any help or pictures would greatly help. As soon as i find out what offset im ordering them.
2010 CC SE
3" lift, BD Triple Dog GT, Airaid MXP, debadged
1998 Chevy Silverado
408 stroker, TH350, NOS fogger, etc...
2004 Grand Prix GTP
RG motorsports tune, 180*, catless, cai
Depends on what look you are going for. If you want the wheels to stick out a little go for the -12. If you want them to tuck under the fenders +20.
06 CC 2x4 LE Majestic Blue. Banks Monster exhaust, banks air box, bully dog, hid lows and fogs. 4" maxtrac spindles, 2" blocks, 5100's up front, 5125's rear. 20x9 KMC XD Addicts -12mm offset on 35x12.5x20's toyo mt
Pinch weld mod and some more. Was on 24" Milanni wheels.
+20 or +14mm if you want to do minimal trimming and +1mm offset if you want a more aggressive look and don't mind doing a lot of trimming. You may run into some pretty bad rubbing with the -12mm but they will give you the most aggressive look. I honestly wouldn't recommend running a 35" tire with that aggressive of an offset with out a 6" lift. It basically comes down to how much trimming you want to do.
__________________ 2006 Radiant Silver 4x4 CC LE
Performance: 2011 Stock Exhaust and K&N Drop In Filter Suspension: NCD 2" Leveling kit and PRG cam bolts Wheels: Fuel Boost 18x9" with 20mm offset wrapped with 275/70-18 Toyo Open Country AT2's Misc: Full Interior/Exterior LED's Plus Super Reverse 2.0 Lights From LegitLED'S, TonnoPro TriFold Tonneau Cover
Sorry to hijack the thread by my question is similar to the original one posted.
Regarding offset, I have a choice between -12 or 12.
305/50R20 is the size I am looking to put on a 2008 4x4 LE with a leveling kit, air bags Bushwacker fender flares.
The current set up is 305/40R22.
12 mm off set will push the wheels out wider? If so what are the consequences, if any, for tire clearance on the given the previously mentioned specs. I would like to go to wider stance if possible.
The less offset means the wider the stance. You should be fine with the -12mm offset because the tire you mentioned is actually a little bit smaller than stock but an 1.5" wider. I am assuming your going with a 9" wide wheel. The -12mm offset will definitely give you that wide aggressive stance. If you ever plan to go any larger than stock you should go with the 12mm. Also what tire are you going with because all manufactures are different the dimensions i used are the nitto terra graps?
The Following User Says Thank You to osiris10012 For This Useful Post:
Haven't actually decided on tires yet, I'm try to figure out wheels first. I found a tire size conversion chart that said 305/50R20 is = 32'' x 12.5'', is a 33'' stock?
How much do the dimensions vary from manufacturer to manufacturer? I thought the dimensions would all be standard.
What I am looking for is 32" or 33" x 12.5 wide R20 or R18 something that works well in snow and looks rugged. I have checked out the BFG TA KO and the Toyo open country AT but I'm not really sure which I prefer. Also open to suggestions on tire selection.
Check out rimsntires.com and click on the size comparer on the left. A good visualizer for how offset, rim size, and tire size work together.
Sent while Autoguide freezes and crashes.
2007 4x4 SE CC BT UpRev Tuned W/ TLPM
S&B CAI W/ 4" Ram Air & DEI Cooltape|Bosch Platinum IR Fusion Plugs|3"x26" Maggy to shut it up
PRG UCA's|PRG Heimed Outter Steering|Bilstein 5100's & 5125's|08 4x4 Coils|1.5" Spacer|C-10 Deavers|315/70/17 BFG's
PRG Traction Bars|eBay Grille|UWS LoPro|Headlight Mod|Tinted Tails|Colormatched Mirrors & Handles
15% Tint All Around|Wet Okole's|WeatherTech Digital Fit Mats|Custom Rear Storage The Stigs Mechanic
The Following User Says Thank You to Mack207 For This Useful Post:
The difference between manufactures is usually somewhat close, but its best to look at their size specifications to be positive.
I'm leaning towards a Goodyear Territory in a 275/70/R18 on 18x9 rims with a -12 offset. Part of the reason is I can get those Duratracs for a smokin' deal new.
Just looking for some opinions on how you guys feel that narrow of a tire will look?
This is the truck as it sits currently. I'm not a fan of the tires and wheels and they have to be upgraded anyway for the winter.
currently its running 305/40/R22
Thanks again for the input guys.
You need a narrower rim or a wider tire. The DuraTracs, at least, are spec'd for an 8.5" maximum width rim. Found the Territory spec's for a LT275/70R18 at Canadian Tire ... same maximum width.
You could go with the shorter LT275/65R18 at 32" diameter but if it were me, I'd get the DuraTrac in the LT295/65R18 at 33.1" diameter.
I am glad I asked. Thanks for clearing that up for me. The 295/65/R18 Duratracs look like the answer.
Thinking that These wheels are the ones. I think a -12 offset should fit?
You might, (very likely will), need the pinch weld mod and front mud guard removal with a 9" width and -12 mm offset and a 33 on a leveled Titan. The -12 mm on a 9" width rim stick out 2" more than stock, so make a bigger arc when you turn.
Then a possible issue is the spokes might rub on the calipers. I had this happen and just got wheel spacers to give 7 mm of extra clearance. I you had to do that, even more likely you would need the PWM. It's not a big thing though, (see the last link in my sig). But depends on what your definitions of "fit" is. If I was going for a 9" with just a level, I'd probably pick a 0 mm, or better yet, a +12 mm if I wanted to avoid the PWM.
