Old 09-13-2004, 06:54 PM   #1 (permalink)
What size 18 inch tires to run?
04 extended cab with daystar leveling kit.
Thanks
Jonathan
zmydust is offline   Reply With Quote
Old 09-14-2004, 07:18 AM   #2 (permalink)
325/60/18 TOYO makes a all treain that would fit.
04 Red Brawn KC SE SOLD!!!!!!!
01 Lightning # 1916
391hp/500tq
braun04 is offline   Reply With Quote
Old 09-14-2004, 08:32 AM   #3 (permalink)
SWEED32's Avatar
Look at my sig... I really like the Nitto's
2004 TITAN C.C. 4X4 Smoke
2.5" Daystar, 325/60R18 Nitto Tires, Helo Wheels
SWEED32 is offline   Reply With Quote
Old 10-12-2004, 02:36 PM   #4 (permalink)
I put 325/65/18 nitto grapplers on stock wheel after 2" revtek kit. had to do some trimming but lil brother is a genuis when it comes to stuff like that. trimmed behind fender skirt and buttoned it back up looks awesome can't even teel it's been trimmed
neworleansmike is offline   Reply With Quote
Old 10-12-2004, 02:55 PM   #5 (permalink)
QWIKWHIP's Avatar
Hey Sweed32, could you tell me a little more about your setup? I'm looking into the same size. What is the wheel offset/backspacing, do have any rubbing issues, and what did you have to cut/trim/modify?? Thanks in advance.
Jim
Old 10-12-2004, 11:01 PM   #6 (permalink)
SWEED32's Avatar
Jim
wheels are 9.5" with a back spacing of 4.5"
no rubbing just had to remove the stock mud flaps
Old 10-12-2004, 11:43 PM   #7 (permalink)
IQ9
Have you had any issues with "tramlining" as 325 are WIDE?
Crew Cab,Pearl White,LE,Venture Clear Bra, Debadged, PML Dif Cover, 285/60/18 Nitto Terra Grapplers & Stillen BBK
IQ9 is offline   Reply With Quote
Old 10-13-2004, 05:38 PM   #8 (permalink)
SWEED32's Avatar
Not at speed a little under braking...
Old 10-13-2004, 06:10 PM   #9 (permalink)
IQ9
That is good to hear. 325s are wide...I want'em
Old 10-13-2004, 09:23 PM   #10 (permalink)
Awesome truck SWEED32, I'm looking at prerunner's kit and the same tire and wheel(maybe) setup you have. Will this set up actually raise the height of the truck cuz I need to fit in the garage.
TITAN4x4 is offline   Reply With Quote
