How do I test the brake actuator? - Nissan Titan Forum
Old 01-03-2013, 09:50 AM   #1 (permalink)
iTrader Score: 0 reviews
Hi, I have a whole set of dash-lights that are on brake, slip and ABS
I have always had the truck this way, and did not care to much about it. Now I found maybe 10000 threads about it and have tested some stuff:
- I went to the dealer, he resetted the thing and thought it was the right front sensor. I replaced the sensor after the lights came back on, did not help...
- I unplugged the wiring at the actuator and tested all connecting: they are all good.
- I took out the ABS fuse, something to do with possitioning, ran it for 1 mile, nothing changed...
So how do I go on now? Actuator?
I am in Belgium, most dealers here have never seen such a car and can't help me.
The truck is a 2005 2WD LE.
Thank you,
Jan
schryvere is offline   Reply With Quote
Advertisement
Old 01-03-2013, 10:15 AM   #2 (permalink)
mjw357's Avatar
iTrader Score: 4 reviews
Re: How do I test the brake actuator?
First thing I would check is brake fluid level. Has the truck ever had the pads replaced?
- 2004 Galaxy Black KC OR 4x4 -
Adam Model 2020 3-horse gooseneck trailer
Old 01-03-2013, 07:36 PM   #3 (permalink)
HRTKD's Avatar
iTrader Score: 2 reviews
Mine did the same thing when I broke one (or more) of the sensor wires on the rear axle.
«ClearBra, Leer 100XQ, MM SI9500 Winch, 18" Magnaflow, Berk b-pipes, Volant PowerCore, AMSoil bumper to bumper, Uprev tuned»
«SAW Coilovers and rear shocks, PRG upper control arms and shackles, Hellwig rear sway bar»
Jim
Old 01-03-2013, 10:33 PM   #4 (permalink)
Hi,
topped off the fluid and checked all the wiring.
I also read about the sensor near the fluid container that could be faulty, how do I test that?
I always read about brake, Slip and VDC lights mine is ABS.
It had the front pads and pads replaced just before I bought it.
Advertisement
Actuator for Tailgate TiTAN- Titan General Discussion 2 10-31-2011 08:19 PM
ABS actuator install G-walker Titan Wheels, Tires & Brakes 0 02-04-2011 07:15 PM
Automobile Magazine - Long Term Titan Test - Brake issues solecky Titan General Discussion 3 12-21-2004 08:03 PM
Need Test Vehicle for Brake Test rkawski Titan Wheels, Tires & Brakes 0 09-30-2004 07:30 PM
SEO by vBSEO 3.3.2
