mud grips and snow - Nissan Titan Forum
post #1 of 20 (permalink) Old 12-02-2013, 08:30 AM Thread Starter
nick bar's Avatar
iTrader Score: 0 reviews
mud grips and snow
I've got 305 55 20 nitto mud graps for my summer tires. however my winter tires I just noticed are pretty bald. instead of spending another 1,000 dollars on tires, does anyone know how bad it really is to use mud tires in the snow? im highly considering just leaving them on for the winter. I guess I should mention too the titan plows about 5 driveways, and we don't USUALLY get that much snow, but last year got a 2 foot nor'easter any input is appreciated, thanks
nick bar is offline
Advertisement
post #2 of 20 (permalink) Old 12-02-2013, 08:41 AM
chadp82's Avatar
iTrader Score: 4 reviews
Re: mud grips and snow
I don't have personal experience, but I have been told mud tires aren't that great in the snow.
If you don't get much snow, you would probably be ok and may want to consider chains for plowing if you need them. A set f chains would be cheaper than tires. Running as large of a tire a you are may make it tough to clear chains in the fenders though
Sent from AutoGuide.com App
05 LE Crew w/ Offroad Package
Bilstein 5100's; 1" Rear Lift Block & 1.5" Strut Spacer
BDPP (2° Advance, WOT removed, Regular Tune)
JBA cat back, Cajun Catless B Pipes
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
A glass of beer shortens your life by one minute, a glass of wine by two minutes, and a day of work by 7 to 10 hours
America!!! (Designed by geniuses, run by idiots)
chadp82 is offline
post #3 of 20 (permalink) Old 12-02-2013, 11:01 AM
I live in Wyoming where we get plenty of snow. I would say 75 percent of the trucks here have mud tires on them. I have personally had mud tires (Goodyear Wrangler MTR and Goodyear Wrangler Duratrac (close to mud) and they both did great). The Duratrac's were better. I mean deep snow and ice and they both did well. These were not oversize tires by much though.
WYTitan is offline
post #4 of 20 (permalink) Old 12-02-2013, 11:47 AM
StormTroopin's Avatar
iTrader Score: 20 reviews
My old mud grapps were terrible in the rain... Wouldn't even want to try snow. They kick *** offroad, but snow... Nope. No way they'll be worth a damn.
MeatBeaterWhore™ TwinTwit #1 "The Big O" Maverick!
GO DUCKS!
StormTroopin is offline
post #5 of 20 (permalink) Old 12-02-2013, 12:25 PM
ostaF's Avatar
iTrader Score: 9 reviews
Mud Graps did well in the snow on a few snowboarding trips to Mammoth and Big Bear. Decent amount of snow, nothing crazy. I kept it in 4WD and was careful behind the wheel, good to go.
1/4 - 12.28 @ 108 mph (60' 1.683)
2006 4x4
Spectre 4" - JWT S7/S2 Cams - UpRev - LS7 TB - MGT90
Doug Thorley LT - Cajun Resonated 2.5 Bpipes - Cajun 2.5/3 Y Pipe
Borla XR1 - TrueTrac - Transgo HD2 - Edge 3500 - Caltracs
M&H MHD-11 - Nitrous Express
Old Photos of the Titan
ostaF is offline
post #6 of 20 (permalink) Old 12-02-2013, 07:41 PM
AZPRO4X's Avatar
iTrader Score: 8 reviews
It's not the snow you should worry about its ICE. Once you figure out their limitations you will be fine.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
The Following User Says Thank You to AZPRO4X For This Useful Post:
NBhunter80 (12-02-2013)
post #7 of 20 (permalink) Old 12-02-2013, 07:46 PM
OneQuick06's Avatar
It all depends on how well the siping is on your mud tires. No siping = no bueno in snow and ice.
2006 Galaxy KC BT SE
Mods: Click here Pics: Click here
CrayolaWhore™
MonkeyPumperWhore™
OneQuick06 is online now
The Following User Says Thank You to OneQuick06 For This Useful Post:
post #8 of 20 (permalink) Old 12-02-2013, 07:47 PM
NBhunter80's Avatar
I always run mud tires in the winter up here in Canada, and they do just fine. AZPro4x hit the nail right on the head: Mud tires are great in snow but terrible on ice. You will do fine as long as your tires arent too worn and you know your limitations. The main thing is that you need to have some siping left on the tread in order to get any traction on ice. If your tires are worn and there is no siping left, then it is SCARY when you are driving on icy roads or in freezing rain. But if your tires still have lots of life left, just slow down and use 4wd (if you have it) and you will do OK.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #9 of 20 (permalink) Old 12-02-2013, 07:48 PM
NBhunter80's Avatar
Beat me to it.
post #10 of 20 (permalink) Old 12-02-2013, 07:55 PM
OneQuick06's Avatar
Originally Posted by NBhunter80 View Post
Beat me to it.
I don't drive on much ice, but the same is true for all the wet roads I travel on throughout the year. Big lugs + no siping = slip and slide. That is why I ride on the tires I have. Wet traction is a must down here.
CrayolaWhore™
MonkeyPumperWhore™
post #11 of 20 (permalink) Old 12-02-2013, 08:40 PM
Treebasher's Avatar
From my experience, mud tires do great in the snow....unless it's cold and there is ice underneath. Not too many tires do well on ice but mud tires are about the worst I've used. BTW, ice fishing will be here soon in MN!
Treebasher is offline
post #12 of 20 (permalink) Old 12-03-2013, 01:08 AM
osiris10012's Avatar
Garage
iTrader Score: 5 reviews
Just be careful and learn how the tires work in the winter and you will be fine. Up here in fairbanks a lot of people run m/t's in the winter and are fine. From what they have told me the m/t's do good in the snow, but you need to be super careful when it comes to ice.
2006 Radiant Silver 4x4 CC LE
Performance: JBA Long Tube Headers, Cajun 2.5" Reso B Pipes, 2.5" to 3.0" CAJUN Y Pipe, TAP Auto Mid Pipe, Borla XR1 16" 40944, Spectre 4" Reso Tip, Vibrant UQ Reso, Uprev Tuned by Seymore4 and K&N Drop In Filter
Suspension: Rough Country 6" Lift, Bilstein 5100's (Middle Perch)/5125's, 1.5" PRG BL
Wheels: Fuel Maverick 20x12" with -44mm offset, Nitto Terra Grappler G2 325/60-20's
Audio: Sundown Audio E10, Mbquart1 Custom Harness, Precision Power BK1800.1D, Sky High Audio 1/0 gauge ofc wiring
Misc: Full Interior/Exterior LED's From LegitLED, TonnoPro TriFold Tonneau Cover, Cajun Axle Vent
osiris10012 is offline
post #13 of 20 (permalink) Old 12-03-2013, 05:49 AM
Scottyb52's Avatar
iTrader Score: 1 reviews
Yeah my pro comps got around fine last year with 18" of snow.
2005 LE
Leveling Kit, M/T 17s, Pro comp MT 33x12.5x17, Airaid MXP,Bully dog GT,Cajuns,RC Traction bars, 5100s all four corners and Two pink car seats for the twins.
Scottyb52 is offline
post #14 of 20 (permalink) Old 12-03-2013, 09:00 AM
misfit482's Avatar
Duratracs do great in snow and ice because it's a winter rated all terrain tire. Mud tires do ok in deeper snow, but as others have said they suck on ice. Especially tires with little or no siping. A great example is the BFG MT. They might as well be slicks if the snow is 1/4" or less and/or there is ice on the road.
'07 CC 4X4 Banks exhaust and intake w/tb screen delete, headlight mod w/ Morimoto switcbacks, legit hid's, XD diesel rims w/ nitto terra's, PRG minilift, PRG UCA's, Sway bar removed, 5100's all around, DK shackles, PWM, AVM, BW pocketflares, PD'd stuff, BL step rails, Streetscene grille, '08 brakes w/ Powerstop D/S rotors and pads, PRG SS braided lines, SM designs bezel kit, red LED's in footwells
misfit482 is offline
post #15 of 20 (permalink) Old 12-03-2013, 09:36 AM Thread Starter
nick bar's Avatar
thanks for the help. yeah the ice is what im really worried about. i dont wanna hit the brakes and slide through my garage. will the weight of the plow and counter weight help with the ice or just make it worse? i guess my main question is do you guys suggest leaving my almost bald goodyears (the factory tires) on or switch to the muds
nick bar is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Mud/Snow/Highway Tires??? SirKeats Titan Wheels, Tires & Brakes 10 11-01-2009 01:30 PM
Mud Grips for a 4x4 Titan 7mag_Jake Titan Wheels, Tires & Brakes 10 04-11-2009 09:12 AM
mud grapplers in snow/ice? krpogo Titan Wheels, Tires & Brakes 2 12-01-2006 07:23 PM
First snow test for the Mud Terrain SXT's KTMNealio Titan Wheels, Tires & Brakes 0 12-01-2005 08:23 AM
Need Help Finding Mud Grips toby ray Titan Problems & Dealer Service 3 10-09-2004 08:59 AM
You may post new threads
You may post replies
