Old 02-12-2005, 05:50 PM   #1 (permalink)
Banned
Squid's Avatar
Mossy design judder proof brake pads for Titan/Armada
This was their January Press Release.
http://www.freshalloy.com/site/featu...ssy/home.shtml
Squid is offline   Reply With Quote
Old 02-12-2005, 05:57 PM   #2 (permalink)
got_titan's Avatar
hey squid i have had these carbotech pads on for about 3000 miles and all i can say is there fantastic. the stop better, feel great and 0 warpage as of 4000 miles. my last truck had been in for service twice before 5000 miles for the brakes. the pads are great and cost only 75.
Old 02-12-2005, 09:43 PM   #3 (permalink)
scsTiTan's Avatar
Hey Got-Titan that sounds great, but right now I don't have the brake problems that seem to be everywhere, however I was wondering about the dust since I do have plenty of that. Do you see an increase or decrease or about the same?
Thanks,
Steve
09 CC LE 4x4 SMOKE
MODS GO HERE!
SOLD
04 KC LE 4x4(BT/OR)
Super Fast Silver
scsTiTan is offline   Reply With Quote
Old 02-12-2005, 09:54 PM   #4 (permalink)
got_titan's Avatar
theres about an 80% decrease in dusting, the back actually shows more dusting than the front now.
Old 02-12-2005, 10:31 PM   #5 (permalink)
HavockWK's Avatar
Thanks for the info!
With all the people who got in on the group buy for these, we should be able to scare up some more reviews after various mileages.
Anyone?
Old 02-13-2005, 06:24 PM   #6 (permalink)
homer's Avatar
Please excuse my ignorance on this subject, but does $75 get you 4 pads or 2? Should the same pads be used all around?
I haven't had a hint of brake judder yet but would GLADLY drop $75 for an 80% reduction in brake dust.
2004 Crew Cab LE 4WD
Deep Water Blue, Graphite/Titanium
Born 02/16/04
Big Tow, Off Road, Bed Extender, Floor Mats, Splashguards, Bed Mat,
OEM Hood Protector, Putco Stainless Steel Bed Rails
homer is offline   Reply With Quote
Old 02-15-2005, 04:22 PM   #7 (permalink)
Stillen
Went on to Stillens site. I wanted to know if I bought from them the new rotors and pads from stillen if I have to disassemble the hubs to get the rotors off. Does anyone know if the rotors are slip offs or do you have to disassemble hubs to get the rotors off? If they are slip offs I was thinking of purchasing the slotted rotor kit and stillen brake pads. This may resolve my warped rotor problems for good??????
Prlauren is offline   Reply With Quote
Old 02-15-2005, 05:04 PM   #8 (permalink)
front 2 pads for $75
Old 02-15-2005, 05:12 PM   #9 (permalink)
Clancy's Avatar
ouch. very ouch.
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Old 03-01-2005, 01:59 PM   #10 (permalink)
I would ask Mossy. It should be 75.00 for the front set, not 2 pads but 4 pads in the set.
I will wait for PBR metal masters to come out, I like these pads for all my vehicles.
Chris 04
04 sedona red SE. JWT intake, full mod stereo with 10" blaupunkt sub. Flowmaster exhaust, undercover plastic bed cover, Westin bullbar, hella lights.
BIGT56PA is offline   Reply With Quote
Old 03-01-2005, 02:09 PM   #11 (permalink)
Chris 04
Sorry, that is what I meant. Two front sets for $75.00.
Old 03-01-2005, 02:58 PM   #12 (permalink)
gr8titan's Avatar
Check the Stillen thread I started here in the "wheels, tires & brakes section". I purchased the big brake kit and it is a direct bolt on replacement. You can also click on the links below my SIG for further details & photos of the install.
Nissan will eventually issue a TSB or recall and the front brakes will be replaced with thicker (by decreasing the fin cooling space) twin rotors designed to be used with "softer" pads.
Any brake specialist will tell you that this (Nissan's) is not a smart approach to the Titan's inherent problem. Nissan dropped the ball when they used the same size diameter on front twin and rear single rotors. The front brakes uses MORE than 60% and the rear brakes LESS than 40% in stopping a vehicle.
This is where the inherent problem lies: THERE ARE NO WARPED REAR ROTORS IN THE TITAN! The rears are just fine however, everytime the brakes are applied, the front pads apply over 20% more energy on the front rotors & over 20% more heat generated. Since the front and rear rotors are the same size & the pad/rotor contact surface are the same, this causes the front rotors to be degraded at a disproportionate faster rate than the rear. If Nissan increases the front rotor thickness (TSB or recall) by reducing the center cooling space, the rotor will be unable to eliminate heat efficiently causing even hotter rotors. Softer pads will just be replaced more often than anyone would like. Nissan just made a "bait and switch" sales pitch.
I for one do not intend to go through this "band-aid" approach. Eventually, this inherent problem will hit us in one way or another. Remember, the Titan is heavy (over 5K lbs) and powerfull (379 ft/lbs stock). Try stopping that stump pulling torque with Frontier brakes!!
When you visit your local Nissan dealer to have your brakes fixed, check the Frontier, Maxima, Altima, etc. Either they all have larger diameter OEM front rotors or have rear drum brakes!!!
Hope this info helps. PEACE
gr8titan is offline   Reply With Quote
Old 03-01-2005, 03:02 PM   #13 (permalink)
"I purchased the big brake kit and it is a direct bolt on replacement."
I would do that also but I have 17" wheels.
Old 03-01-2005, 08:31 PM   #14 (permalink)
Banned
Anyone?
3400 miles here, and no warpage. Total 9400 miles. I had 2 sets of stock pads and rotors under 6k replaced.
Beast305 is offline   Reply With Quote
Old 03-01-2005, 08:32 PM   #15 (permalink)
Banned
The rotors are part of the cause. But the main cause are the pads creating too much heat. Better pads solve this problem.
