I will be the first to say I don't understand tire/wheel sizing. Here is my situation.
I have 20 x 8.5 wheels and I just install the PreRunner 2" lift.
How big of a tire can I get. Currently my tires are 12" wide. I want narrower tires but much taller. What I have right now are 305 50/R20. What I am after if maximum height without hitting the wheel well when I turn the wheel. I want to go narrower as well the wide tire cut my mileage by 2.MPG.
TIA
[SIZE=3]Canton, Ga Drive it or Ride it like you STOLE IT!
I don't know the max height with a level kit. I've heard rubbing but I don't know if that was from width or height. Most say you can't go over 35", and then you are rubbing somewhere.
The way tire sizing works is a ratio. 305 is how wide in millimeters. 25.4 mm per inch means 12 inches. 50 is how high off rim in a percentage of the width. In this case, 50% is 6 inches. With 20 inches of rim, this makes about a 32" tire, 20+6+6.
Stock was 265/70/18. 10.5 wide, 32.6 high.
I'm going with 305/55/20. 12" wide, 33.2 high.
Hope this helps.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
I think a 305/55r20 is about the biggest tire you will be able to fit without a lot of trimming. Toyo and Nitto both make tires in this size. They look really good on a level Titan. I don't know if you're looking for an all-terrain or a street tire, but the only tire I can think of that has a smaller footprint than what you have and may be a little taller is the BFG A/T 285/55r20. They are 32.5" tall, which is pretty close to stock.
TIA
Both of the following will fit:
The 285/55/20's are 32.3 inches in diameter (0.3 inches shorter than stock)
They cost about $320.00 each installed(BFG TA KO all terrain).
The 305/55/20's are 33.2 inches in diameter (0.6 inches taller than stock)
They cost about $280.00 each installed(Nitto Terra Grapplers).
________________________
2004 Titan SE CC 4X2, Built 11-15-2003
Purchased 12-12-03
Galaxy Black, Popular SE pkg, Capt. chairs/gated shifter, Factory Fog lights, UtiliTrac/Bedliner pkg,PRG Leveling Kit Front and Rear
See my signature. At full lock they rub just ever so slightly but nothing I will lose any sleep over. I am not aware of a bigger tire (in 20") that will work with just a leveling kit.
However, Loufish is running a 315/70/17 BFG A/T (34.5" Diameter) and PreRunnerGreg is running a 35/12.50/17 BFG M/T. Both have a bit of rubbing I think.
2 tires you might want to look at with the 20" Wheels are
The Goodyear Wrangler HP 275 60R 20 OD= 32.9
and
The Michellin LTX M+S 275 60R 20 OD= 33.0
These are both thiner and tall and should have no problem with any rubbing.
I am lifting my Titan 6in. If i put 20 by 8.5 wheels on there will that look lame ?? or will the 20 by 10 look better ??
ps i am new at this.
20x10 looks much better, but I'm a little biased.
You will get a little rubbing turning the wheel all the way...I'm going to do the pinch weld mod today, should eliminate it completely. I'm also putting on traction bars today, because the axle wrap is horrific with the bigger tires, just something to keep in mind...
2008 Titan SE CC, Popular Package, Big Tow, Bed Utility Package, Sliding Bed Extender Click here to see my mods Click here to see my pics
Wife's Ride: 2005 Infiniti QX56 4x4
My Other Ride: 2007 Sea Doo Speedster 200
AKA: Crossdresser Whore™
The Bald Avenger® "Why is the rum always gone?"
First for the origional poster: Look into a 275.65.20. The Terra Grappler by Nitto comes in that size. They are about 34" tall and 10.83" wide. Probably need the pintch weld mod but you'd have to test fit to know for sure. Anyone have any experience with this size of tire on their titan? They should be just under 1.5" taller in overall diameter.
To Barratt 20x10's with a lift look great. You can really get a nice stance and this tire, wheel and lift combo. You will probably want to run a wide tire usually 35x12.50-20. They will ware better on the 10's will last longer because of it.
