I just wanted to ask what is everyone running as far as the tire pressure in their Titan's? I have the 17 inch off road BFG'z rugged trails.... the truck recomens setting the pressure at 35 psi cold.... I do run that... even tire wear all the way around.... I was just wonding if some of these guys posting that theu are getting gas mileage in the 20's are running a higher pressure!?! just curious what you all are running....
The owners manual say when you rotate the tire.... got front to rear + rear to the front keeping the same tires on the same side of the truck... I was looking on the BFG website and it says to cross em!?! Any recomendations.... thanks for your time!!!
Welcome to Titan Talk......
Welcome to Titan Talk.....firefighterforusn...I always cross rotate-em .........and my same tires are at 38.5 psi all around...you can also SEARCH on TT and find out a lot.
Peace-Tom Gaelic Ale
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac.
In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, Rear Axle Vent Mod, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
Might have to experiment for your terrain.....
Originally Posted by firefighter4usn
Hey thanks tom.... I appricate all of your help.... and I will continue searching on TT... take care!!! is 38.5 a hard ride?
When the temps. of the tire drop......it is softer.....no need to pressure up higher..........is what I have been trying with some success for my terrain.
You may have to experiment for yours. With some weight in your Titan the smoother the ride.....empty will be rougher for a Off Road 4 x 4 Big Tow Titan.
Peace-Tom Bass Ale
