Ok, I'm looking to find a replacement tire for my stock 18" wheels. Looking for something like a 33", with a somewhat aggressive tread, either an all-terrain or mud terrain style. I don't want to be spending alot on them though, are there any economical choices out there?
__________________ 2005 Nissan Titan CC SE 4x4 6" Stage 1 Procomp Lift, SAW Coilovers-Front, Bilstein 5125 Series Shocks-Rear, Total Chaos Shackles, Custom Skid Plates
So...you want some big-a$$ tires, but don't want to spend much....I suppose you would like these tires to provide good traction AND wear like iron???
Just playing with-you...
PRG Performance Kit w/SAW's
Born 9/2004
I was at Les Schwab last week and was quoted about $1018 for some Toyo AT tires. They had a much more aggresive tread and are a bit bigger than the stock Goodyears. However, I think clearance is an issue as these trucks don't have much room to work with unless you have a lift. Pretty spendy though for four new skins.
Tahoetitan
born 7-23-04
White SE CC
Utili-track bed with spray in bedliner
Power Captain option
Big Tow
Leer 100R Campershell
Yakima Rack
Factory OEM Seatcovers
Husky Floor Liners
EGR Bugshield
MrGrille Billet grille
Custom fit sunshade
Aries Oval Tube Steps/Stainless
Yeah, i know exactly what you mean. I plan on ordering the PRG leveling kit this week, to gain clearance. I too like the looks of the Toyo Open Country A/T in this size:: LT325/60R18. it says that it will be around a 33.6 OD. Anyone know where to get a price on these?
Mine are basically the same as the Toyos, but with lightning bolts on the sides. $250+/- a tire. The outer diameter isn't going to be what gets you, it will be the width. You won't rub with the tires centered or at full turn. However, at half turn the tires are going to rub like crazy the inside of the tire wells. Mine rubbed and are about 1" more narrow and same outer diameter. THey even rubbed on the grey piece that is the trim for the sidestep. I had to use a heat gun and warp the plastic as much as possible to make mine fit. You'll probably have to cut some out to get yours to fit. I looked at those and considered them before buying the ones I have now. If they made them in a 305/65 I would have gotten them but I couldn't find an A/T in the right size for an 18" wheel. The 17" guys have the 295 and that's a good fit. Hope this helps.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
Here are some pics I obtained from this website. I have looked at the 305/60 18's too and I like them a lot. All I am waiting on is to wear the factory rubber to the point where I can convince my wife it is "safety issue."
From what I recall, this guy had a 2-2.5" front lift and did not expericnece sinificant rubbing (as I stated ... from what I recall).
'04 White SE 4X4 CC
Utility Bed Package
Daystar 2.5" Front Lift
There are a couple of guys running Toyo or Nittos in the 325x60r18 range, it can be done and most of the users say that they did some minor trimming...
For me, probably on my next tire change, I will use nittos 325x70s
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Ok, so I don't mind having to trim, as long as it's nothing major. Like say the inner fender needs trimmed, thats fine with me. BUT... I'd also like to keep my mudflaps on there too, is that gonna pose a problem??
Hey 54warrior,
I'm running with the terra grapplers 305/55/20 and have no problems with clearance. I did not have to trim anything and my mudflaps are a good inch to 2 inches away from my tire.
__________________ My Titan Gallery
2005 Nissan Titan LE 4x4 Smoke w/Big Tow Pkg
305/55/R20 Nitto Terra Grapplers N2 20x9 Rims By MC2 - DF Flowmaster 50 Series Exhaust w/MF Tips - *2 Degree Timing Advance - OEM Bugshield / OEM Step Rails - Utilitrack System w/Bed Extender - Undercover Tonneau HardCover - Westin Chrome Bullbars New Toy - 2008 Super Bee SRT-8 #581 of #1000 - Fully Loaded w/ Option Groups I, II, III - Sunroof - Airbags Front & Side - Remote Start - Best Times 0-60 4.578sec - 1/4mile in 12.9567 Out Of the Box.
The Terra Grapplers 325/60/18 are about the same diameter with only about 1/2" wider thread, so basically if you choose the right wheel size and offset, you should be right with minor, trimming...
Suspension Mods:
Has anyone ever look at the BFG AT 325/65/18. Looking at the tire calculator they look to be about the same size. Should not be any difference in the speedo . www.4wheelonline.com has them on sale $296.99, buy 3 get 1 free.
Those are 2" taller and 2 1/2" wider. No way you will fit those on a stock truck. You will need a PRG lift, trimming, and maybe they will fit. 6" lift would be better. Mine are smaller and barely rub and stick out the sides 1/2". I needed to heat up the tire wells and flex them to make them fit.
Stock is 10.5" wide, 32.8" Tall
Mine are 12.25 wide, 33.4" Tall
Those are 13" wide, 34.9" Tall.
