Old 04-24-2005, 08:10 PM   #1 (permalink)
004 Crew Cab LE.. 20x9's w 325/50/20's
I think I can do this, and appreciate feedback b4 I invest. I have a 2004 LE CC, with PRG lift, and am looking at 20 x 9 rims, and Hankook Ventus RH06 325/50/20 rubber which is ....WIDE..(diameter is about the same, 32.6 vs 32.79.
Accordingly, I would want it to fit well, and look even better. By using this calculator, and comparing the stock 18x8 rims with a 25 offset and the stock 10.5 inch wide 265/70/18's against some new choices, this would fit, and finding a rim with the right offset, could be ok on clearance.
http://350zx.com/tire-wheel.html
The new sidewall size is 6.4 inches vs stock 7.3 inches, so I lose .9 overall. The width with these new tires would be 12.8 vs 10.5 on the stock tires.
Now if I could figure out how to get the right offset so I could turn without rubbing.....
Input is really appreciated by those in the know...
2004LECC
Radiant Silver
PRG FE Lift
Loaded
4x4 BigToe
Window Weatherflectors
Hood Guard
Roof Vent Deflector
K&N
Banks Exhaust
Truxedo
Dash Top Cover
Utilitrac Toolbox, Sliding Tray Lower (sittin in the garage...DontLikeThem)
NIssan SeatCovers (nice!)
Soon to be Amp'd Upward
TickleMeTitan is offline   Reply With Quote
Old 04-24-2005, 08:44 PM   #2 (permalink)
92TripleBlack's Avatar
They will fit if you want to trim.
The width is what will make them scrape more than the height. The scraping comes in at halfway turned. At this point, the edge of the tire will rub the inner rear fender wells. Mine do and mine are 20 mm narrower than yours. I needed a heat gun to melt my inner tire wells to fit. You will need to cut or lift.
Also, that wide will stick out the sides. Mine stick out slightly and I get some spray from rain/etc streaking on the doors. I need flares from a qx56 to fix this. You will need flares or rocks will rip up your door paint.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 04-25-2005, 06:02 AM   #3 (permalink)
VShortt's Avatar
He is lifted.
New List of Mods Coming soon
Old 04-25-2005, 04:38 PM   #4 (permalink)
So, if I'm PRG Lifted, does that change the rub issue? And that note about dirty doors, good point! Perhaps I'm a bit to WIDE eyed about this and need a bit skinnier version....
Old 04-25-2005, 05:05 PM   #5 (permalink)
VShortt's Avatar
Many of the wheel/tire combos around here are 305/55R20. This ultimately yields a tire height of 33.2 inches. With the PRG lift, I have not heard of anyone reporting rubbing issues. The only issue left would be the backspacing on the wheel. It will definitely fit and if you see any issues with rubbing once you mount them, simply do a little trimming. It will fix you right up.
Old 04-26-2005, 02:13 PM   #6 (permalink)
I know he's lifted. Lifted with 305/55/20 would be fine. But not sure with the 325s. And that still won't change the fact that they will be sticking out the sides. Where mine rub the surface is verticle. Lifting it 2.5" vertically wouldn't change the rub factor. Trimming should make them work in the end but I'd go for the 305 over the 325 anyway. They look plenty mean and fill out he space nicely.
Old 04-26-2005, 09:04 PM   #7 (permalink)
This calculator that I just found out about may help you on the offset choices: http://toy4two.home.mindspring.com/offset.html
I see that your other one does offset as well, but there are too many parameters there for me, I like looking at one variable at a time
Justin311 is offline   Reply With Quote
Old 04-27-2005, 07:25 AM   #8 (permalink)
This should help you get a better visual of what your dealing with. It also gives you estimated speed changes
http://www.miata.net/garage/tirecalc.html
jree is offline   Reply With Quote
