Old 04-28-2005, 05:52 AM   #1 (permalink)
RedAlert's Avatar
Send a message via AIM to RedAlert
Tire Size Help....
I would like to get some new rims for the Titan, However I am not into lifting the truck up, So my question is what is the Maximum size I can go up to without any rubbing or trimming.
Thanks
RedAlert
RedAlert is offline   Reply With Quote
Old 04-28-2005, 07:28 AM   #2 (permalink)
avroflyer's Avatar
Do a search to help you better narrow down your options, but from what I've seen 20 inch seems to be the allowable maximum, however I think someone put 23s on their's? Anyway, keep in mind a lot of people with these 20 inch + or 295-315 or 33-35" tires have at the very least a leveling kit on the front.
_________________________
Jim Reeves
Canteen (its not for everybody!!!) King Cab SE 4X2
Off-Road, Big-Tow, RF power-captain
Mods:
PRG Front Level
Magnaflow single 3" in dual 2.5" out exhaust
K&N Series 77 Intake
ARE LSII Hard Tonneau
MAAP Challenger Tube Steps
Carriage Works Billet Grille
American Racing Burst Wheels
Aluminum Dash Accents
Aluminum Pedals
avroflyer is offline   Reply With Quote
Old 04-28-2005, 08:52 AM   #3 (permalink)
92TripleBlack's Avatar
Mine. I needed a heat gun to stop rubbing but no trimming. Just heated up the plastic of the inner fender and pushed it away from the tire. Small area the size of my palm. Any larger and trimming would have been necessary. The surface that needed bending was vertical so I don't have any rubbing during long wheel travel.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 04-28-2005, 09:06 AM   #4 (permalink)
m0wens's Avatar
Thanks
RedAlert
Take a look at the wheels and tires I have for my Titan. I did not have any rubbing nor did I have to have a lift.
My Titan Gallery
2005 Nissan Titan LE 4x4 Smoke w/Big Tow Pkg
305/55/R20 Nitto Terra Grapplers N2 20x9 Rims By MC2 - DF Flowmaster 50 Series Exhaust w/MF Tips - *2 Degree Timing Advance - OEM Bugshield / OEM Step Rails - Utilitrack System w/Bed Extender - Undercover Tonneau HardCover - Westin Chrome Bullbars
New Toy - 2008 Super Bee SRT-8 #581 of #1000 - Fully Loaded w/ Option Groups I, II, III - Sunroof - Airbags Front & Side - Remote Start - Best Times 0-60 4.578sec - 1/4mile in 12.9567 Out Of the Box.
m0wens is offline   Reply With Quote
Old 04-28-2005, 11:14 AM   #5 (permalink)
QWIKWHIP's Avatar
I have the same size wheel and tire you do and I have the 2" front lift and still had a small amount of rubbing. What are the offset on those wheels??
Old 04-28-2005, 11:33 AM   #6 (permalink)
m0wens's Avatar
Hey QWIKWHIP,
I want to say there 18mm offset but I need to verify to be sure.
My Titan Gallery
Old 04-28-2005, 11:43 AM   #7 (permalink)
QWIKWHIP's Avatar
Hey QWIKWHIP,
Hmm, that is odd. Mine are 12mm offset which means yours stick out more and in turn would cause more rubbing when at full lock. You do have the 305/55 and not the 305/50 right? Are you sure your not rubbing though? You might not even hear it rub. Not that I don't believe you, it just seems weird that with the same size I had some rubbing and I also have a 2" lift.
Old 04-28-2005, 01:54 PM   #8 (permalink)
m0wens's Avatar
That is correct. I do have the 305/55. I don't know if this matters or not, but I did order my wheel/tire package from Nissan. Nissan calls it the "Performance Package". The dealership in my area actually installs the wheel/tire package as an upgrade on a couple of the Titans.
My Titan Gallery
Old 04-28-2005, 01:57 PM   #9 (permalink)
m0wens's Avatar
QUIKWHIP,
After looking at my truck again, I really don't have an offset on my wheels. It's just about flushed.
My Titan Gallery
Old 04-28-2005, 02:46 PM   #10 (permalink)
QWIKWHIP's Avatar
QUIKWHIP,
I bet that's the difference than. The offset is a huge factor in the fitment. So yours are actually set in a little further making it less likely to rub. Very Cool. It just proves what a difference offset can make.
Old 04-29-2005, 12:16 PM   #11 (permalink)
m0wens's Avatar
Hey QWIKWHIP,
Did you adjust your speedo when you put you new wheels/rims on your truck?
My Titan Gallery
Old 04-29-2005, 12:28 PM   #12 (permalink)
RedAlert's Avatar
O.K So let me get this straight...305/55/R20 seem to fit with out any rubbing so long as my Offset is approx the same as the OEM tire???? what is are OEM offset?
RedAlert
Old 04-29-2005, 02:10 PM   #13 (permalink)
m0wens's Avatar
RedAlert
I don't believe the OEM wheel/tire has any offset from what I can remember. So to answer your question, you will want as little or no offset in choosing your wheel/tire combo.
My Titan Gallery
Old 04-29-2005, 02:59 PM   #14 (permalink)
QWIKWHIP's Avatar
Hey QWIKWHIP,
No I didn't, the tire diameter difference is less than 2% so it's not enough to be concerned about. You get more variation than that from the factory. lol
And to answer about the offset, the 18" oem wheels have a +25mm offset. Wheel width also has an effect on offset too. Check out this http://350zx.com/tire-wheel.html it will help you determine what is closest to OEM.
Old 04-29-2005, 03:04 PM   #15 (permalink)
m0wens's Avatar
[quote=QWIKWHIP]No I didn't, the tire diameter difference is less than 2% so it's not enough to be concerned about. You get more variation than that from the factory. lol
Yeah I hear ya.
My Titan Gallery
