Old 05-11-2005, 09:37 PM   #1 (permalink)
Send a message via AIM to toadvb20
what size tires and rims?
i was just wunderin what was the biggest tire and rim i could probly go without putting a level kit on? and then what size to go after i would put a kit on? the reason i am asking for input is cause i am not sure what i want to do first. get a nice set of wheels and tires or level it first.
toadvb20 is offline   Reply With Quote
Old 05-12-2005, 09:22 AM   #2 (permalink)
92TripleBlack's Avatar
The outer diameter max would be 33.5" and the width would be 305. If you go wider, you will need flares or mud will be hitting your doors. If you go wider or taller, you will be scraping. My combo maxes out what you can do but there are other combos that do the same: 295-70-17 for example is a good one. 285-65-18 is also if you can find one and so on. This is for stock. If you put a level kit on, you can go 1-1.5" taller. Wider will still give you the spatter problems.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 05-12-2005, 09:31 AM   #3 (permalink)
m0wens's Avatar
My wheel/tire combo is in my sig. It pretty much fills up the wheel well. Be sure not to have to much offset if you go with 305/55/20.
My Titan Gallery
2005 Nissan Titan LE 4x4 Smoke w/Big Tow Pkg
305/55/R20 Nitto Terra Grapplers N2 20x9 Rims By MC2 - DF Flowmaster 50 Series Exhaust w/MF Tips - *2 Degree Timing Advance - OEM Bugshield / OEM Step Rails - Utilitrack System w/Bed Extender - Undercover Tonneau HardCover - Westin Chrome Bullbars
New Toy - 2008 Super Bee SRT-8 #581 of #1000 - Fully Loaded w/ Option Groups I, II, III - Sunroof - Airbags Front & Side - Remote Start - Best Times 0-60 4.578sec - 1/4mile in 12.9567 Out Of the Box.
m0wens is offline   Reply With Quote
Old 05-12-2005, 09:22 PM   #4 (permalink)
what would be a good offset if i went with a 20" rim. 18mm or so?
Old 05-16-2005, 03:09 PM   #5 (permalink)
m0wens's Avatar
Try to get as little if any offset. Something less than 12mm should be fine.
My Titan Gallery
Old 05-16-2005, 03:40 PM   #6 (permalink)
The 20's are the best!
p_bratton is offline   Reply With Quote
Old 05-16-2005, 05:06 PM   #7 (permalink)
Vegas04's Avatar
the best offset would depend on the width of the wheel that you are buying.
a wheel that is 20"x9" actually has a total widty of 9.5" because of the lip around the edge of the wheel. So if you bought a wheel that was 0 offset you would have 4.75" of backspacing and 4.75" of front spacing. If the offset was +12mm then you're backspacing would be 4.75"+12mm (whatever that is.)
If you bought a rim that was 20"x8" with +12mm offset then your backspacing would be 4.25"+12mm. when it comes to wheel fitment, 1/2" is a big deal.
BTW: my wheels are 9" wide and I have +2mm offset and my tires stick out past the fender about 1/2." I think it looks great. If you do a search for my user name you'll find pictures.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 05-22-2005, 02:03 PM   #8 (permalink)
larger wheels & tires
are you willing to sacrifice 15hp for just going to larger tires & wheels?
reds is offline   Reply With Quote
