Anyone every noticed on the sidewall of the the stock offroad tires the max inflation pressure is 35 psi? I've been running 38 since I got it. Seems pretty low to me.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
iTrader Score: 1 reviews
35 PSi MAX. ...it does seem low????
Originally Posted by HavockWK
Yep! I saw that and that sux. I run about 38-40 in mine because I hate it when they start bulging on the sides at 35 & under.
Same here......10% over =38.5 PSI.......rides fine and still smooth!
Peace-Tom Highland Beer
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with 08 Big Tow-E-Loc, Blizzard Graphite/Titanium Interior, Popular Package, Bench Seat, Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-4th set, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades-2nd set, Optima Red Top battery.
You have to remember there just P rated tires (passenger) not the LT's.
2004 Titan LE CC 4X4 Offroad
PRG Performance Package Lift
PRG Rear Shackles- PRG Sway Bar End links
Bilstein Rears
Detroit Truetrac
315 BFG's All Terrain's
Does the tire rating match for the Big Tow??
So is the stock tire the correct tire for a 4 x 4 with Big Tow???? Can it handle any tongue weight loads from a trailer or loads from a full bed of cargo? It sounds under-rated for towing and loads.
Peace-Tom Coffee
Peace-Tom Coffee
I just hauled a load of sand in my truck and they were fine, you might look at the sidewall to see what the max loads are for the tire, but it would be nowhere near what a light truck tire would be. When mine ware out I'm going with the BFG All-Terrains which are rated as an LT. http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
I went ahead a looked at the specs on the two tires
BGF Rugged Trail P28570r17 max load 2575@35PSI
BFG All Terrain KO's LT28570r17 max load 3195@65PSI
Bilstein Rears
Detroit Truetrac
