We've had this issue here on similar wheels. Basically, the sensors do not fit correctly in the hole in the wheel for the stem, so you need to use an o-ring to help seal it up. trouble is finding an o-ring that fits well. Once you do, and you get it to seal, you need to often times re-set the sensors at the dealer. Even then, the lights still come on every now and then. Most people just take the sensors out altogether, and just put regular stems in. I don't exactly know why the sensor light still comes on once everything is working fine, it could be the distance between the sensor and the pick up unit, the pressure in the tire, a few different things, i'm not really sure....
Even our service manager's titan had the same issue, so he just removed the sensors altogether.
It's a pain, i don't like sensors n-e-more hehe
