Old 06-07-2005, 11:47 AM   #1 (permalink)
What are good tires to consider?
Whats worked best for you guys?
Im looking for a tire mostly on road and some off road but i need great wear and grip to the road.....
any ideas?
Thanks Robs
panhandletitan is offline   Reply With Quote
Old 06-07-2005, 11:50 AM   #2 (permalink)
Vegas04's Avatar
you'd get more responses if you said you want "the most bad-a$$ looking tires they make!!!"
in which case I would tell you Super-swampers.
but for tread life and offroad effectiveness: BFGoodrich All Terrain K/O
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 06-07-2005, 12:00 PM   #3 (permalink)
I have the BFG AT KOs and they seem o.k. so far.
Old 06-07-2005, 12:02 PM   #4 (permalink)
bristolVATiTan's Avatar
I have had good experience with pro-comp tires. I used the pro-comp at's on my old 01 frontier and they did very well on and off road and they come with a 50,000 mile tread warranty.
04 xe w/6" pro-comp lift, 17x9 extreme alloys 1079, 35x12.50 pro-comp x-terrains,AEM Brute Force intake, flowmaster exhaust, full eclipse stereo w/10" dvc sup and 600 watt amp. 83 Dodge Ramcharger w/4" lift 35x12.50 mtr's 4.56 gears and auburn limited slip, built smallblock with 400hp 02 honda xr250r w/fmf exhaust, litz racing suspension
bristolVATiTan is offline   Reply With Quote
Old 06-07-2005, 12:09 PM   #5 (permalink)
BFG At KO all the way. I traded my last Silverado in with just over 100,00 miles on the tires and there was still a little tread left. Excellent tire.
(Titanless )
The_Man is offline   Reply With Quote
Old 06-07-2005, 12:23 PM   #6 (permalink)
ptgarcia's Avatar
BFG All-Terrain. It's the best AT out there. If you want a more aggressive tire the BFG Mud Terrain is an excellent choice. It works great on everything but mud...go figure. It really should be called an AT+ or something like that. Both tires will give you 50k miles if you keep them rotated and at the recommended pressure. Good luck!
Pauly
Old 06-07-2005, 02:32 PM   #7 (permalink)
Sammy Sandbag's Avatar
While I liked the BFG KO's, I'm going to give the nod to the Nitto Terra Grapplers. They seem to be wearing similar to the BFG's, but ride slightly better with a better self cleaning tread design. If Bridgestone makes a suitable size Deuler Revo then I'd say go with those, but I don't believe they do.
-Counsel Yourself
Old 06-07-2005, 07:34 PM   #8 (permalink)
m0wens's Avatar
I lean more towards the Nitto Terra Grapplers. Performance is great on and off-road IMO. The ride is a bit stiffer than stock but it handles like it's on rails when cornering. As far as off-roading goes, it does a decent job in the mud when getting to my deer lease.
My Titan Gallery
2005 Nissan Titan LE 4x4 Smoke w/Big Tow Pkg
305/55/R20 Nitto Terra Grapplers N2 20x9 Rims By MC2 - DF Flowmaster 50 Series Exhaust w/MF Tips - *2 Degree Timing Advance - OEM Bugshield / OEM Step Rails - Utilitrack System w/Bed Extender - Undercover Tonneau HardCover - Westin Chrome Bullbars
New Toy - 2008 Super Bee SRT-8 #581 of #1000 - Fully Loaded w/ Option Groups I, II, III - Sunroof - Airbags Front & Side - Remote Start - Best Times 0-60 4.578sec - 1/4mile in 12.9567 Out Of the Box.
m0wens is offline   Reply With Quote
Old 06-07-2005, 10:45 PM   #9 (permalink)
loufish's Avatar
I'll weigh in...from personal experience I say BFG A/T KO's, they wear great, hook up in most off-road stuff great, and work very well on the street.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
