Old 07-01-2005, 09:00 AM   #1 (permalink)
Stillen Brakes 5K update - FANTASTIC
These things are only about 90% broken in at 5K! Returned from an 800 mile road trip yesterday and took a look at the rotors and oddly enough the front right rotor appears 99% broken in with only the slightest hint of machining work, and the front left looks to be “less” broken in with more visible hatching left on the rotor face.
The rears still display very visible machining.
Oddly enough despite what looks to be an uneven break in the truck stops straight and true- RIGHT NOW !
One comment from a friend that drives a Tahoe- “This thing stops on a dime”
Stopping power has been increasing every trip- I have not yet been able to detect fade.
At one point the 5 freeway a tight group of us went from 85 mph to a dead halt – full “panic” stop - no fade no drama no wiggle whatsoever just firm controllable rapid deceleration.
Brake dust has been decreased significantly.
One note – this rotor pad combo DOES require warm up for max stopping power- I notice when I head out in the morning the first few cold stop require more effort and stopping distances are generally longer until you get some heat in the system. Nothing alarming but it is definitely noticeable.
Ill post some pics this weekend and look at the fluid level to see if I can get a feel on pad wear.
Davegvg
04 Titan CC le 4X4 big tow/ Stillen OEM brakes/ ss lines
21ft Laveycraft Sebring tunnel (406 small block 100+ mph)
Cr-500
24ft weekend warrior
2 segway human transporter
Kalamazoo BB4 dual fuel SS grill
Toy update
Z3 left with the x-wife
Maxima wrecked by borrowing sister 4 weeks ago
Banshees sold to make room for turbo hyabusa powered sandrail.
Davegvg is offline   Reply With Quote
Old 07-01-2005, 10:53 AM   #2 (permalink)
overdose's Avatar
question: are these the Stillen XD rotors you're talking about?
01/04 SE KC 4X4 Galaxy Black Line-X | Grill |Steprails | Monroe Reflex Shocks | PML DC| AC GK|
overdose is offline   Reply With Quote
Old 07-01-2005, 11:07 AM   #3 (permalink)
92TripleBlack's Avatar
Question: Who makes the brake pads and what model are they? I know they aren't going to work on a stock setup but it sounds like they put an autocross grade on your brakes like EBC red instead of EBC green, which would require the heat up period. Just curious.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 07-01-2005, 07:59 PM   #4 (permalink)
Overdose- these are the stillen OEM direct replacement cross drilled rotors and pads.
92 triple black- I believe they are made by rotor pros and oem'd by stillen and I am using their "metal matrix" pads. They arent EBC for sure as Ive used EBC before. Take a look -http://www.rotorpros.com/index.htm
Had the same setup on a 95 Maxima and it worked very well didnt take as long to break in though.
Davegvg
Cr-500
Toy update
Old 07-01-2005, 08:47 PM   #5 (permalink)
I am having a good experience with these brakes & pads also. These rotors seem to be very hard.
Old 07-02-2005, 12:23 AM   #6 (permalink)
I also have the same rotors and my truck has 12,000 miles and i tow a 26ft tralier and have no brake fade?
blacksheeptitan is offline   Reply With Quote
