Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Wheels, Tires & Brakes
User Name
Password
bigger rotors with bigger wheels - being discussed at Nissan Titan Forums in the Titan Wheels, Tires & Brakes section.
Old 10-09-2005, 06:04 PM   #1
heath22
I know that bigger is better and bigger pads = better stopping and all that...but if I put 22" wheels with a 305/45R22 tire which is the same rolling diameter as my stock 18's with 265/70R18 tires then how is that more stress on my rotors and pads when coming to a stop? I wouldn't guess the weight to be more since the tire is smaller and the wheel may weigh more but wouldn't it all kinda wash with the OEM setup? Now the look of a small rotor my be visually out of wack with a big open wheel, but that is just looks. Again, I know what all will come back with, but again, on paper what's the difference? Maybe I'm just tired and need to clear my mind, but I was just thinking about this while I was online looking at wheels for my Titan.
Thanks,
heath22 is offline   Reply With Quote
Old 10-09-2005, 06:06 PM   #2
Sammy Sandbag
Sammy Sandbag's Avatar
Look at the manufacturer's specifications for the wheels/tire weights and compare. It might be a bigger difference than you think, or not. I really don't know since I don't have experience with "big" wheels.
-Counsel Yourself
Old 10-09-2005, 06:10 PM   #3
PTitan
PTitan's Avatar
Yeah what he said.
PTitan is offline   Reply With Quote
Old 10-09-2005, 06:44 PM   #4
chung_chang
I'm no expert but I've searched a bit on the internet. From what I've read, here are couple of points:
1. metal weighs more than rubber so more metal and less rubber usually means more total weight. I'm sure there're exceptions to this as forged wheels are very light. Certain offroad tires like all-terrain and mud-terrain with multiple steel plies may weigh more than other tires of the same size.
2. weight on tires and wheels are different from weight on other parts of the vehicle. When tires and wheels spin, weight multiplies (rotating mass). I'm not certain by what factor but I've read anywhere from 2x to a whopping 8x! So worse case, extra 10 lbs of weight on each wheel/tire becomes 320 lbs of extra static weight for the brakes to handle (10 x 4 x 8 = 320).
Again, these are from my own research on the internet and I have no prior personal experience so I could be way off.
chung_chang is offline   Reply With Quote
Old 10-09-2005, 06:58 PM   #5
rcantu
rcantu's Avatar
I have 22's and there's definitely more rotational mass. they're also much more heavier than stock. It's a PITA to load and unload them in the bed.
as far as braking i would say there's definitely a difference in stopping. I can't guage how much much definitely noticeble. I have the tsg on the rotors for judder and about 3k-4k so far and seems to be fine.
pics of the Titan
Old 10-09-2005, 07:02 PM   #6
92TripleBlack
92TripleBlack's Avatar
Thanks,
Not much.
Bottomline is the new redesigned rotors are more than enough for braking. Think of it this way, these brakes are large enough for towing 9k, they can handle your rims. You can go bigger for looks, but it isn't necessary. Just remember not one maker of drilled rotors offers a warranty as they crack. If you want to get bigger rotors, get plain or slotted. Slotted will vent a little better, and also cause more dust and pad wear. Coatings are gone after 100 miles on the braking surface but usually remain elsewhere.
If you want other rotors than the new stock ones, I'd get these with a set of ceramic pads.
http://www.tirerack.com/brakes/brake...tor&perfCode=S
http://www.tirerack.com/brakes/brake...ads&perfCode=P
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 10-10-2005, 01:45 PM   #7
heath22
Originally Posted by 92TripleBlack
Not much.
That is exactly what I was thinking, the rotors are made for a high towing capacity and I don't really tow anything and won't be for a few years, so I shouldn't have to change the rotors. I got into this discussion with a friend at work after talking about supersizing my wheels and he suggested new rotors. The wheels I want won't show much if any of the rotor, so appearance isn't a concern. Thanks for the replies...
Old 10-11-2005, 09:16 AM   #8
ptgarcia
ptgarcia's Avatar
To be sure you need to check the weights of your existing wheel/tire combo and the wheel/tire combo you're looking to purchase. Overall weight is one consideration, the other is how that weight is distributed. Larger wheel/tire combos have more mass farther away from the axis of rotation, which equates to more inertia. This makes it harder to get them turning, and once turning harder to get them to stop. If you go with a 20"+ combo you will lose braking power. Is it enough to concern you? I don't know, only you can make that determination.
Pauly
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
