Old 11-15-2005, 08:12 AM   #1 (permalink)
Help me calculate gas mileage with 35"s...
Hi there, I tried several tira size calculator but couldnt find one that would give be the right % from my oem BFG 285x70r17 Vs the BFG BT 35x12.5r17...
Ive tried with 3 gas tanks already and got weird results, what I did was just add an extra 5% from the larger tire and got about 10% better gas mileage VS the oem tires, should this be right?
THX in advance
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Audio Mods:
Cooming soon:
HIDs and Yellow Fogs...
Old 11-15-2005, 09:19 AM   #2 (permalink)
Banned
Contra's Avatar
Re: Help me calculate gas mileage with 35"s...
um that doesnt sound right
but lets see pics of the truck with those monsters on it
Contra is offline   Reply With Quote
Old 11-15-2005, 09:29 AM   #3 (permalink)
kartman's Avatar
Im not sure what you are trying to figure out. WIth bigger tires you need to remember that your odometer and speedo will read slow as you will be traveling farther with each revolution of the tire.
Rebar Wrangler
Old 11-15-2005, 09:43 AM   #4 (permalink)
PhatSami's Avatar
http://www.izook.com/gearcalc.htm
Here's a good link to some useful tools when trying to figure out that kina stuff.
According to this the 35 is 2.3" taller, thus traveling 7.2" more per revolution. That's a ton more distance considering how many revolutions a tire makes on a tank of gas.
"If I can touch it, I can destroy it". Greg Graffin - Bad Religion
PhatSami is offline   Reply With Quote
Old 11-15-2005, 10:00 AM   #5 (permalink)
Mike H.'s Avatar
I think your tire circumference is now about 6% higher. So if your odometer says you went 300 miles, you actually went 318 miles. Just factor that in when you check your mileage - add 6% to the miles travelled before you divide in your gallons used.
Works the same for speed. Add 6%. If your speedo says 60, you are going about 64.
Mod links (clickable):
Old 11-15-2005, 10:11 AM   #6 (permalink)
CoachBoone's Avatar
Can't you just get the speedo recalibrated?
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 11-15-2005, 10:11 AM   #7 (permalink)
PhatSami's Avatar
yep that's what I got too.
Old 11-15-2005, 10:38 AM   #8 (permalink)
kartman's Avatar
Not yet, the Hypertech powerpac should allow you to correct for tire and gear changes when it comes out though.
Rebar Wrangler
Old 11-15-2005, 10:39 AM   #9 (permalink)
Mike H.'s Avatar
Nope. Nobody makes anything yet, and the dealer can't do anything with them either. It's not like the GM system where other tire sizes can simply be input. That'd be too easy.
Old 11-15-2005, 04:20 PM   #10 (permalink)
Yea thats exactly what I tought It was right in between 5 or 6%...
How can it be possible that Ive gotten better milage with the 35s?
Suspension Mods:
Audio Mods:
Cooming soon:
Old 11-15-2005, 04:41 PM   #11 (permalink)
It is like having a higher (numerically lower) rear axle ratio.
3.357 x 32.7/35 (approx) = 3.136 (closer to the non Big Tow of 2.94)
Old 11-16-2005, 07:42 AM   #12 (permalink)
54warrior's Avatar
I calculated my stock 265/70-18's to be about 32 inches,,, soo 35/32=app. 1.10 %, therefore, for every 100 miles my odometer says, i actually go 110.
someone correct me if i'm wrong... i have been avg. about 14-15 mpg
i also have the non-offroad version with the 3.73's
what does this make my final gear ratio?
found my gear ratio thanks to the http://www.izook.com/gearcalc.htm website
thanks phatsami
Old 11-17-2005, 07:26 AM   #13 (permalink)
Get a hold of a GPS and you can take all the guess work out of it.From stock tires to a set of 35" Toyo M/T my truck was out 6%.
canuk is offline   Reply With Quote
Old 12-13-2005, 07:54 PM   #14 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
better gas mileage? i'm about to get some 35's. hehe
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 12-14-2005, 11:42 AM   #15 (permalink)
Tyltan's Avatar
I got worst mileage. I didn't attention how much worst but it is a lot worst with 35".
Tyltan is offline   Reply With Quote
How to calculate gas milage wareagle Titan General Discussion 46 04-20-2008 04:57 PM
guys/gals who "flashed" or "reset" ecu grunkster Titan General Discussion 52 12-20-2005 12:05 PM
Gas mileage and performance with 20" wheels NissanCowgirl Titan General Discussion 14 11-06-2005 03:22 PM
Calculate tongue load from wheelarch height? jumpy Titan Suspension 3 08-10-2005 06:08 PM
Minnesota Titan Owners - Check out "Minnesota Titans" thread in "Midwest" region. Half Shovel Titan General Discussion 4 03-06-2005 07:00 PM
