Old 11-26-2005, 10:15 AM   #1 (permalink)
Send a message via AIM to toadvb20
bad wheel studs and lug nuts
has anyone had problems with striped wheel studs and lugs nuts when having tires put on. i just had new winter tires put on and either the people puting reinstalling the wheels are stupid or their is a certain way the need to be installed. so far the have messed up 4 studs and lug nuts. i have been back to the place 4 times and i have to go back 1 more time. i got pirrels scorpian A/t put on . but their is a tire out of round too. so watch for those.
toadvb20 is offline   Reply With Quote
Old 11-26-2005, 10:19 AM   #2 (permalink)
Re: bad wheel studs and lug nuts
Are they using an air impact wrench?
Old 11-26-2005, 10:20 AM   #3 (permalink)
37L1's Avatar
I have rotated my own tires twice now with no problems so draw your own conclusions regarding your installer's abilities.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 11-26-2005, 10:36 AM   #4 (permalink)
the first time they istalled them everything was fine. then i was getting a bad vibration in the steering wheel. so i had to go back. the checked for balance and stuff. well thats when the crap started. they were putting them on with a air gun. well stey messed up 2 lugs. so then i left and i still had a bad vibration. so i went back again so they could double check for out of round tirs. well then they messed up another stud and broke one stud. so i went back for a 4th time this moring so they could replace them all and give me 4 new tires by mastercraft cause pirrels r special order. they said if they take them off and brake another stud i can't drive my truck. so no they ordered 24 studs and lugs and i have to go back for a 5th time. i told them after the 2nd visit to hand tighten every single lugs and use a go to tighten to nissan specs. well they said they did but they still screwed up
Old 11-26-2005, 10:44 AM   #5 (permalink)
I have had good luck at Discount Tire. They use a torque wrench. I would run from any shop that uses an air wrench to put on the lug nuts. In addition to messing up the studs & nuts, they can warp the brake rotors with an air wrench.
Old 11-26-2005, 10:53 AM   #6 (permalink)
Mr. B's Avatar
Did you really state that you can warp a brake rotor with an impact wrench?
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 11-26-2005, 12:39 PM   #7 (permalink)
scr38's Avatar
That is correct. Nissan has a warning about this in the Service Manual.
Old 11-26-2005, 02:04 PM   #8 (permalink)
Mr. B's Avatar
I wonder if Nissan chose to manufacture their rotors from tin-foil.
Old 11-26-2005, 02:43 PM   #9 (permalink)
Stop by, I can prove my theory.
http://www.deere.com/en_US/parts/hom...ue_wrench.html
Old 11-26-2005, 05:48 PM   #10 (permalink)
Austin's Avatar
I had a lugnut gall up the first time I changed my OEM wheels - there must've been something in the threads of the stud from the factory.
I've also had two lugnuts gall up when removing my wheels after getting the truck back from the dealer.
Also, if you're using aftermarket wheels which are lugcentric vice hubcentric, you can scrape the studs on the side of the stud holes and transfer material to the threads of the studs, which will then gall up the lug when you put it on.
*shrug*
They're not very expensive, and they're not difficult at all to change out, front or rear.
MY04 SE King Cab 4X4 SOLD!
Old 11-26-2005, 06:02 PM   #11 (permalink)
A lot of "jap" trucks don't have case hardened studs like old "american" trucks. I learned my lesson with ISUZU troopers. Now 1st thing I do when I bring home a new car is to take off all the wheels and ANTISEIZE the studs. Then put it back together with a torque wrench. YOU MUST ALWAYS START THE NUTS BY HAND THAT MEANS FINGERS. Your tire guy probably started them with impact wrench! You'll never have rusted on lugs again. But after a couple of days go back and check the torque again. No broken lugs,No warped rotors. If someone else does your tires always double check torque and tire pressure. I've left with loose wheels before. It happens!
squatch is offline   Reply With Quote
Old 11-27-2005, 03:37 AM   #12 (permalink)
Mr. B's Avatar
I too am a fan of Never-Seez, and I've been know to use it on everything including gaskets....my dad on the otherhand hates the stuff and grips about me using it when he comes across it on our projects.....He says it's the only product in he's ever seen that "one drop can paint the world".
Old 11-27-2005, 08:34 AM   #13 (permalink)
Austin's Avatar
Those type of lubricants are fine to use in many situations, but you really shouldn't use 'em on wheel studs.
What value do you torque to after you put antiseize on the studs? I'll bet they're too tight...
Old 04-29-2007, 08:43 PM   #14 (permalink)
What IS the correct torque for the factory lugnuts?
MishMash is offline   Reply With Quote
Old 05-02-2007, 10:38 AM   #15 (permalink)
mjw357's Avatar
I had one foul up on me once, all hand tools. I had to go buy a new lug nut, cleaned up the threads on the stud with a hacksaw blade. Must be really soft steel.
Hellz yeah!
this guy is NUTS!!!!! goathead Off-Topic Discussion 12 05-12-2005 08:03 PM
XP Driving me nuts Nuckle Off-Topic Discussion 5 12-07-2004 03:33 PM
ok car audio nuts.... Titanpower Titan Interior Discussion 1 09-26-2004 03:52 PM
17" Offroad wheel lug nuts-no shoulder?? PHOEBISIS Titan General Discussion 1 08-10-2004 05:43 PM
T-nuts / C-nuts for Utilitrac. Doghouse Titan General Discussion 6 03-04-2004 04:01 PM
