Old 12-01-2005, 09:21 PM   #1 (permalink)
MuskyHunter's Avatar
I miss my Dueler AT Revo's
Finally snowed today and was looking forward to tear through it. With my old GMC and the Dueler AT Revo's, there wasn't a drift, incline, or untracked road that stopped me and the old beast. I really can't say that with the 18" Goodyear Wrangler SR-A's. Com'on Bridgestone... lets see some of those 18"Revo's, which in my opinion are one of the best "all around" light duty truck tires out today.
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage
www.secretlake.net
Old 12-01-2005, 09:27 PM   #2 (permalink)
Old Speed's Avatar
Re: I miss my Dueler AT Revo's
i agree also i wish they would make 18's in them!
05, Smoke titan, SE, king cab,w/ big tow pakage
Old Speed is offline   Reply With Quote
Old 12-04-2005, 02:50 PM   #3 (permalink)
CJ3FLYR's Avatar
They're that good? Do they last? Maybe I need a set...
Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
CJ3FLYR is offline   Reply With Quote
Old 12-04-2005, 03:24 PM   #4 (permalink)
Since my 89' Silverado was new I always went with Goodyear MTs because that's what it came with. Last tire change I found that the MTs were no longer available. I went looking at different consumer groups for tires, and the Bridgestone Revo kept appearing with the highest ratings. I bought a set a for the (now) old work truck, and they are the best tires that I have ever used. I have 8K miles on them and they are good in rain, sand, okay in mud. They ride, corner well and are quiet. When the time comes I'll put them on the Titan even if it means a wheel change.
rico387 is offline   Reply With Quote
Old 12-04-2005, 05:53 PM   #5 (permalink)
Sammy Sandbag's Avatar
I agree. Had Revos on my Blazer, best AT tire I ever had. I wish they would come out with a 33x12.50R17 or metric equivalent.
-Counsel Yourself
Old 12-04-2005, 08:11 PM   #6 (permalink)
Jamesn's Avatar
Truely the best out there! But they will cut your gas mileage a bit and were bad enough allready.
05 2x4 KC SE
Prefered pack
Big Tow
Bed Package
20% tint
Borla cat back Exhaust and AEM
Fog lights
Billet 4pc Grill[/i]
Grounding Mod
"I got a fever...and the only prescription is MORE COWBELL!"
Jamesn is offline   Reply With Quote
Old 12-04-2005, 09:44 PM   #7 (permalink)
That really depends. My gas mileage isn't any worse now with my Nittos than with the SRA's. It also helps that my wheels only weigh 20lbs a piece.
-Counsel Yourself
Old 12-04-2005, 10:43 PM   #8 (permalink)
WIS-key's Avatar
Thumbs up Re: I miss my Dueler AT Revo's
I bit the bullet and went with the 265/70-17 Revo's. (I've got the 17" OR wheels.)
My BFG's were toast at 31K - not too bad for an OEM tire; they did stay quiet, but there are better ways to spend money on tires.
With the 265/70's, I've lost about 1/2" of overall height, but I can't really tell by looking. I'm guessing the height difference was minimized by going from a set of almost completely bald 285's (less than 2/32" left) to brand new 265's.
Some observations:
- As the BFG's wore down, they would scare the h*ll out of me in the rain.
- Last winter, about 12K miles before I replaced them, I had the BFG's out in the snow - I was not impressed.
- The BFG's _did_ do fairly well in the sand - NC outer banks - without airing down. The ABLS actually did it's job in 2WD - I could get the truck moving, even in loose sand. 4WD was awesome.
- On dry pavement, the Revo's seem to handle a bit better and are very quiet. (1.5K miles so far...)
- The Revo's are _great_ in the rain - it's much harder to break the back end loose, and quick stops have a much lower "sphincter factor".
I'm looking forward to the first snow to see how well the Revo's do. I may be heading up to Snowshoe (WV) in a couple of weeks, so I may get my chance then.
If anyone is interested, I'll let you know how they're holding up as time goes by with regards to traction, wear, noise, etc.
Anyone want to see pics? (They'll have to wait 'til tomorrow...)
-Rob
WIS-key is offline   Reply With Quote
Old 12-04-2005, 11:03 PM   #9 (permalink)
Yes, let us know what you think and post a pic. I have contacted Bridgestone about making the tires available in the 18" size stating they would likely command the market for 18" Titan replacement tires.
I thought of buying some 17" rims and putting Revo's on, but it is not a cost that I want to bear right now. Snow hasn't been that bad yet and got through 5 1/2" snowfall yesterday okay.
www.secretlake.net
Old 12-05-2005, 09:55 AM   #10 (permalink)
KTMNealio's Avatar
Send a message via AIM to KTMNealio
Get some BFG's in 285-65-18.....?
- Nealio
2005 SE - Smoke CC 4x4
My Titan's wheels and tires
KTMNealio is offline   Reply With Quote
Old 12-05-2005, 08:01 PM   #11 (permalink)
Thats a lot more tire than I need especially at about $260 a pop with mounting and balancing. Need to preserve street tire ride and noise characteristics with some dirt road traction.
www.secretlake.net
Old 12-05-2005, 08:05 PM   #12 (permalink)
92TripleBlack's Avatar
Uh, someone just got them for $206 mounted. They are also quieter and softer riding than the stock Goodyear and continental junk. The stock tires are that bad.
BTW, I too wish they made the duelers in our size. When will 18" rims get there just dues. Doesn't everymaker make 18" these days? Give me a break.
92TripleBlack is offline   Reply With Quote
Old 12-05-2005, 08:31 PM   #13 (permalink)
WIS-key's Avatar
I wonder how much more they will charge if they start making Revo's in 18's - I was able to get the Revo 17's for $152 mounted and balanced.
Pics will have to wait - it's been raining for the last 24 hours (WX station says 1.71" of rain) and it's around 34 degrees. No snow in the forecast, though... :-(
-Rob
Did I miss something krh2 Off-Topic Discussion 20 05-17-2005 02:41 PM
5 Chrome Helo Maxx 6 / Bridgestone Dueler A/t 693 Ii dcrobt Buy/Sell 25 12-03-2004 03:26 AM
