Old 12-08-2005, 05:51 AM   #1 (permalink)
ttammunek04's Avatar
****Attention all tire and rim gurus*****
Due to no tire manufacturers pressing any 18" tires that I can find anywhere, I am considering swapping my 18" rims for the 17" off-road rims. I believe there is a broader selection of tires in the 17" size. This may sound like a really stupid question but here goes, If I swapped to the 17", would there be any danger in me burning up my rear-end or frying my tranny? I was talking to a guy about it and he said, "You better not do that!! That truck was designed to run 18" rims and you'll mess up your tranny and rear-end if you change rim & tire sizes." I thought that was a load of crap. Am I right? Any help would be appreciated.
2004 Nissan Titan SE KC
2006 Polaris Sportsman 500 EFI
Mods:
K&N Drop in Air Filter
Flowmaster Delta Flow 40 series exhaust
Custom Built Diamond Plate Drop-in Tool Box
AVS Bug turd deflector
P265/70/18 Bridgestone Dueler Revos
ttammunek04 is offline   Reply With Quote
Old 12-08-2005, 06:33 AM   #2 (permalink)
Yukon Titan's Avatar
Re: ****Attention all tire and rim gurus*****
Not a rim guru, But it seems to me that the rim size is only relevant if it interferes with the brakes. Otherwise the rim size does not matter. As long as the overall tire diameter is the same as, or close to stock, your good to go.
Yukon Titan is offline   Reply With Quote
Old 12-08-2005, 06:42 AM   #3 (permalink)
Mike H.'s Avatar
The truck was designed to run with minimum 17" wheels to clear the front brakes. Some 16" will even fit on the rear. There is actually slightly less drivetrain stress (very slightly, probably unmeasurable) when using the 17" wheels, as the mounted assembly weighs slightly less.
I may be partial, but go with the Centerlines. They are VERY light. Mine are 6 pounds lighter than my factory 17" offroad wheels were.
Mod links (clickable):
Old 12-08-2005, 07:25 AM   #4 (permalink)
Sammy Sandbag's Avatar
Ditto, my Stingray IIIs only weigh 20lbs a piece. And to answer the original question: go slap whoever told you that. The only issue with changing wheel size is brake caliper clearance. If you're going with the OR 17"s, obviously that's not an issue. Most 17"s will work fine, however some might have clearance issues.
-Counsel Yourself
Old 12-08-2005, 07:55 AM   #5 (permalink)
tillery444's Avatar
Don't listen to that guy, he's the same one that used to give me wheel & tire advice. Every one else be on the look out and don't take any advice from the guy pictured below!
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
PC traction bars & lift
BFG 315/70/17 T/A KO's
PC Extream Alloy 1089 stealth black, 17-9 wheels
[/img]
-[/img]
It's better to have it and not need it, Than need it and not have it!"
tillery444 is offline   Reply With Quote
Old 12-08-2005, 10:13 AM   #6 (permalink)
KTMNealio's Avatar
Send a message via AIM to KTMNealio
Yeah, a guy in highschool once told me he burnt his rear end up cuz he had 16's on the rear and 14's on the front of his car... LOL !
- Nealio
2005 SE - Smoke CC 4x4
My Titan's wheels and tires
KTMNealio is offline   Reply With Quote
Old 12-08-2005, 11:56 AM   #7 (permalink)
Mike H.'s Avatar
Hmmm, I did not go back and check the paperwork. If they are 20#, that's a whole lot less. My OR wheels were 32# boxed to ship. So it is more like 11# less for the Centerlines (subtracting off the boxes).
Old 12-08-2005, 12:09 PM   #8 (permalink)
Not sure what you're saying, but 20lbs is what Centerline actually stated was the wheel weight. I haven't been able to physically check, because I ordered them with the tires already mounted. Did you have the Stingrays or another model, because I'm sure there's a weight difference between them?
-Counsel Yourself
Old 01-01-2006, 10:48 AM   #9 (permalink)
If your Titan came with stock 18's, downgrading to 17's would be a problem. The 17's will not clear the calipers.
JohnJohn8 is offline   Reply With Quote
Old 01-01-2006, 11:08 AM   #10 (permalink)
Yes they will. All Titan's have the same size brakes.
-Counsel Yourself
Old 01-01-2006, 11:09 AM   #11 (permalink)
Demondw3's Avatar
Does the Off Road pkg come with different brakes than the Non Off Road? I thought it was a suspension and gear difference.
Demondw3 is offline   Reply With Quote
Old 01-01-2006, 11:15 AM   #12 (permalink)
Look above you.
-Counsel Yourself
Old 01-01-2006, 11:18 AM   #13 (permalink)
Demondw3's Avatar
Look above you.
Beat me by a minute. I have to learn how to type faster and feed the kid at the same time.
Old 01-01-2006, 11:30 AM   #14 (permalink)
Or you could have the kid learn how to feed himself and devote all your time to typing faster, just depends on your priorities.
-Counsel Yourself
Old 01-01-2006, 11:39 AM   #15 (permalink)
Demondw3's Avatar
wife says that TT is my priority so I guess he better learn to feed himself
to all Vin # gurus out there rudy
