Old 12-23-2005, 05:19 AM   #1 (permalink)
speedo and 35s
what are you guys doing to correct your speedometer when going to taller tires. Im putting on t/a k/o 35s THANKS!
joe dirt is offline   Reply With Quote
Old 12-23-2005, 06:36 AM   #2 (permalink)
Vegas04's Avatar
Re: speedo and 35s
At this point- there is no way to correct your speedometer and other wheel speed sensors. But someday there will be a way.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 12-23-2005, 09:50 AM   #3 (permalink)
Mustard's Avatar
Re: speedo and 35s
Just know that you are going 5% faster than the speedo is reporting
Mustard is offline   Reply With Quote
Old 12-23-2005, 10:46 AM   #4 (permalink)
TITAN220's Avatar
Re: speedo and 35s
Check out this site:
http://www.bigcustomwheels.com/rt_specs.jsp
It'll tell you exactly how much the speedometer has changed. With 315's it should be 5% higher. With mine it's 7% higher.
2004 Titan CC LE 4X4
OR/BT Package
Volant/Banks
Rancho 4" lift
Eagle Alloy 114's
Toyo M/Ts 35X12.5 20's
TITAN220 is offline   Reply With Quote
Old 12-23-2005, 11:31 AM   #5 (permalink)
Tyltan's Avatar
Re: speedo and 35s
I thought it is slower 5%.
Tyltan is offline   Reply With Quote
Old 12-23-2005, 11:33 AM   #6 (permalink)
Mustard's Avatar
Re: speedo and 35s
If your speedo reads 70 you are going 73.5mph. I verified it with my GPS.
Old 12-26-2005, 05:20 PM   #7 (permalink)
Vegas04's Avatar
Re: speedo and 35s
did you get those 315s installed yet? how is the rubbing / trimming going? I have a set in my garage and I can't decide whether to put them on or not.
Old 12-26-2005, 05:32 PM   #8 (permalink)
TitanicDJ's Avatar
Send a message via MSN to TitanicDJ
Re: speedo and 35s
I have a 6" lift and 315's, they rub a little while cranking the steering wheel all the way to the left.
Here's a site I like to use to figure out the speed and other info:
http://www.4lo.com/4LoCalc.htm
DJ
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
TitanicDJ is offline   Reply With Quote
Speedo m0wens Titan Wheels, Tires & Brakes 4 04-21-2005 08:00 PM
Speedo Stuck on 20 mph TITAN MAN Titan General Discussion 4 03-05-2005 04:07 AM
speedo correction??? squatch Titan Performance Modifications 1 01-02-2005 12:37 PM
Speedo OFF? Batman229 Titan General Discussion 13 11-03-2004 09:16 AM
VDC and speedo experiment the head Titan General Discussion 5 10-26-2004 03:07 PM
